2.0 sri crank wanted
bobdylan55
Post by bobdylan55 »
looking for a 2.0 turbo sri crank as mines scorred on one of the main bearings. obviously not looking for too expensive as itll probably be cheaper to get it reground. cheers
Re: 2.0 sri crank wanted
I'm stickng my neck out nervously here but I'm fairly sure someone said on here years ago that the crank is the same as the Diesel XUD unit. Maybe someone could look on servicepox to confirm?
Nope.
00000501G1 CRANKSHAFT 8,816.41 HRK :
D8F 0 05A20A CRANKSHAFT PULLEY INJECTION XU10J4R AND BVM
D8F 0 05A20L CRANKSHAFT PULLEY INJECTION XU10J4R AND BVA
D8F 0 05A25A CRANKSHAFT PULLEY TURBO INJECTION XU10J2TE AND BVM5
I think the point was it'll fit and it's stronger (although I've no idea if that's true or not).
Thanks for looking so quick steve 8)
Maybe it was to do with the strength as you say? the Diesel one would be forged steel.
bobdylan55
i believe the hdi has only 4 counter weights where as the sri and such have 8 counter wieghts. is the gti 6, s16 or mi16 etc crank the same?
