i mafter a clock set for a phase 2 406 hdi with elcectronic speedo drive.
there must be 5 dials and 2 multiplugs.
The 96 code on the top must read
9642948580
the speedo has decided to stop working apart from when you press the brakes which is most annoying!
if anyone has one i could do with it this weekend and will be traveling down to south-end on sea tomorrow as well as mitcham possibly from shropshire so if anyone inbetween has one can you please txt me you contact details to 07891848777
cheers
James
clock set wanted!
- Captain Jack
Re: clock set wanted!
Is it just the speedo clock that doesn't work? Take the whole unit out and solder all the joints to ensure there are no dry ones - it's a common problem with an easy fix
- Blue406
- 406 Gimp
One that the coupes are not immune to either!Captain Jack wrote: it's a common problem with an easy fix
