ignition barrel and keyblade for a 1998 1.9td
wiring and plugs must be intact.
will consider complete lock set, but not too bothered about the doors etc.
Cambs
2001 2.2HDI Estate
2001 2.2HDI Estate
- Captain Jack
Re: ignition barrel and keyblade for a 1998 1.9td
What's the issue? You may be able to repair the existing one.
combination of key jamming in barrel which i have pretty much resolved (but not entirely convinced) but also dodgy elec switch on rear of barrel, meaning the heater fan, and climate control panel often only work after a waggle of the key in the ignition. It all has a very worn, loose feel about it, so would rather swap for better one.
Cambs
2001 2.2HDI Estate
2001 2.2HDI Estate
