steve_earwig wrote:Blimey, they must have been feeling in a forgiving mood
In all fairness I didn't do it on purpose. But I was bloody lucky I just popped it into the roundabout a little fast and let go of the throttle and it slid out... dunno how I caught it
Sorted out the tube and the wiring
I got illumination now
Oh and swiss, this is where you should get your feed...
It really is interesting because even without full throttle at 3000rpm I can make 15psi. But also at full throttle at 2500rpm I can make 15psi. Peak boost seems to be 16psi at 3000rpm in 4th. It’s also interesting how you can make decent progress but only have 6-10psi or even less. Not only that I do a quite abit of engine braking and as the revs go up even with no throttle so does the boost.
Oh and that pipe sends the pressure to the fuel pump which them enables a little man in the engine with a bucket to pour fuel into the cylinders
swiss wrote:I believe 'boost compensator' is the term we're looking for here
You named your guy with a bucket Boost Compensator? Poor guy Mines called Allan
Right on the pillars of the doors is black vynil. The pillar on the drivers side door had vynil on it that was cracked quite badly do I decided to be shot with the lot
Heres a Before...
Pulled it off
Tidies it up with some tardis...
Give the car a clean including wheels and tyres..
And bobs your Uncle
