4 x Hoggar wheels with 4 different 215/55 x 16 tyres all with at least 4mm tread
1 x modified instrument cluster surround. 4 dial type with the lion in the middle with the lion, dial rings & odometer surround painted in silver model paint. Bought as an experiment, but have since picked up a set of Rapier clocks. Also comes with the clear plastic front in case the buyer breaks theirs taking the clocks apart.
1 x Autoleads PC99-X44 wiring harness with smart lead adaptor. For use on multiplex (round stalk) 406s, 307s, Citroen C5s, etc so that you can fit an aftermarket stereo & retain use of your steering column remote. Doesn't include the patch lead which is the part that you buy to match the aftermarket stereo.
