First of all, I'd like to say a big hello to you all as a new member here. I'm from the Volvo V40 side of the fence and have had great help from the Volvo forums in the past, and this one looks just as good, if not better!
I have just purchased a 1999 (V Reg) 1.8 petrol on Friday, and it was running sweetly on Saturday morning when I went to put fuel in. Then my wife too it out and it hesitated a few times during the 20 mile journey, and then cut out near to home (thank goodness). Now it will not start again...
I've scoured these forums for possible common faults, and I've checked the TDC sensor with a multimeter, and all appears good with that. I took off the coil pack strip and popped a spare spark plug (from my Volvo) into one of the 4 holders an d turned it over without seeing it spark. I've checked the ingoing power to the coil pack strip and thsat'd giving a voltage.
So would I be correct in assuming that the coil pack strip and given up on all 4 plugs? Are these a common fault on this model? I also had somebody hold the multrimeter to the plug connector and to earth (the engine) and no voltage was seen while turning the engine over...
By the way, the seller has mentioned that he had an intermittent fault of it running poorly/hesitating and the garage thought it may be the idle control valve and gave it a clean. The problem went away (as do all intermittent faults
Many thanks for any help/suggestions that anybosy has.
