here is loads of random stuff i found in garage as im trying to get money for holidays.
flywheel not sure what its off, 200mm so maybe 1.9 gti?
http://img85.imageshack.us/img85/2264/26072010070.jpg
flywheel 2, again not sure what its off, maybe a gti6? looks to be about 215mm
http://img819.imageshack.us/img819/4691/26072010071.jpg
camshaft, z stamped in end, so i believe its from my bros tu 1.4 xsi engine before he changed to catcam.
http://img517.imageshack.us/img517/5518/26072010072.jpg
oil cooler from xu10 block.
http://img153.imageshack.us/img153/9065/26072010075.jpg
gearbox arms from xsara vts gearbox (for modification maybe?)
http://img714.imageshack.us/img714/4830/26072010076.jpg
406 2.0 turbo boost piping
http://img210.imageshack.us/img210/5298/26072010077.jpg
406 2.0 turbo cam cover - will probably fit all 8v, but doesnt have a breather on it
http://img180.imageshack.us/img180/9985/26072010078.jpg
selection of lower engine mounts. i believe one is a 406 one with bigger driveshaft bearing holder, and one is a smaller 309 gti one.
http://img823.imageshack.us/img823/333/26072010079.jpg
selection of cambelt covers and sprockets etc.
http://img833.imageshack.us/img833/7884/26072010080.jpg
selection of pulleys and random stuff
http://img828.imageshack.us/img828/1226 ... 10081f.jpg
more random stuff
http://img837.imageshack.us/img837/5158/26072010082.jpg
alternators think ones a 306 derv, and not sure on the other. also 3 lumention ht leads, managed to loose one dough. and water hose about 8mm ID iirc.
http://img821.imageshack.us/img821/720/26072010083.jpg
2.0 8v turbo head, complete
http://img251.imageshack.us/img251/9803/80215589.jpg
xsara vts gearbox, used but ok valeo vts clutch, fuse board, rear lights (have both somewhere)
http://img137.imageshack.us/img137/1373/bootparts.jpg
citroen synergie clutch kit brand new. dont know what it will fit other than a synergie tho?
http://img137.imageshack.us/img137/7328 ... clutch.jpg
1.9 gti engine in parts. Was being built by my bro for his friend but has changed his mind so now my bro needs rid of it out of the garage. he might build it up if right money is offered.
http://img299.imageshack.us/img299/7430/205engine.jpg
garage clear out
- 1.8 8v
garage clear out
Reason: Non-working picture links changed to URLs 'cos they're ENORMOUS!
- 1.8 8v
Re: garage clear out
bit of a longshot but see you have some turbo parts im after a coolant pipe which runs from the wateroutlet on the back of the block, i belive it runs to the stat housing? dont spose you have anything laying about? and also what sort of cash you after for the GTi engine?
- 1.8 8v
hi i dont have the pipe your on about but are they not all similar? I can check service box for you later if you want. As for the 205 engine are you wanting it in parts? Or built up.
- 1.8 8v
are you on about the take off that goes up from the outlet? if so that goes to the heater matrix hose that goes through the bulk head. the other one goes to the bottom drivers side of the rad. Then there should only be one other take off which goes to the turbo.
- 1.8 8v
Ah right.......thought there was a pipe that ran from there to the stat housing.....my bad
and was just interested in price for the engine as it is mate.
- 1.8 8v
hes after £80 for the engine. He says its from a cti with flat top pistons but with a gti head which gives a bit higher compression aswell. Its been cleaned and painted etc so all in good order, just needs putting together. Will need a few parts like piston rings and gaskets etc, the stuff you would change anyway.
cheers
cheers
- 1.8 8v
anybody want anything? offers on all otherwise itll be going in a skip.
