noticed when i changed clutch cable today that the release arm has a large amount of play in it ,,,
((( im still getting judder setting off in 1st )))) clutch was replaced 5 months ago
is it possible that the nylon bushes have gone that holds the arm in place ? seems a lot of play/movement to me, im really pissed off now cant gt rid of this judder
the squeek is coming from the release arm as tho its sticking, you can feel it vibrate as well if you touch it when clutch being pressed and released..
When re-fitting the clutch cable you're suppose to hook/fix/mount it to a point close to the steering rack in the front beam/cross member. This helps ratcheting of the cable. Have you fixed/mounted it properly? If all is well then it must be from the bushes on both sides of the fork lever shaft, the fork bearings ??
2007, 407SW HDi 2.0l
1980, Volkswagen GolfD 1.6l
1996, 1.8(8v), SL ( The BEST Peugeot I've ever had. It kept me working on it, fixing it almost every day, I miss you)
steve_earwig wrote:I have a suspicion that the diaphragm spring's broke
thought as much, eliminated from possibilities since he had replaced the whole thing just 05 months back..
