Aux Belt
Aux Belt
noticed my aux belt has a groove on it on the back as you look were it goes around the alternator, i only had it changed 3 months ago,
the grove seems to run all round the belt , is this normal i didnt take notice of my old one,
its on the back - smooth side of the belt
Re: Aux Belt
It should be smooth on the back, sounds as though something has carved a gouge in it unless I'm mistaken! :?
It's a real piece of p1ss to change, definitely a diy job.
Re: Aux Belt
i thought it should be smooth, i will take it back to the garage 2moro and see what they say, might be under warranty yet if its the belt at fault.
Re: Aux Belt
went back to the garage today, he said it isnt right, its wearing wrong with the groove,
what could cause this, the smooth side of the belt has a groove in it and its now not smooth anymore its rough :?
i can only see the 1 pulley that the belt goes round touching the smooth side, could that pulley be on its way out ?
i have to go back monday and he will look closer into it he was busy today,,,
