406 core plug leak 97 2.1 td
StefanYHU
1.6 8v
Post by StefanYHU »
Hey fellas,
After this cold winter I had to replace my radiator, once I changed it I filled up the system with collant only to find the coolant was pouring straight out of where I think the core plugs are.
I think the coreplug is beneath the fuel pump, am I right in sayin this? Is there an easy way to get at them?
thanks very much
Re: 406 core plug leak 97 2.1 td
Looks like you're right, there are a couple right where the pump goes:
13 - 023403 x10 PLUG-CORE DIAM 27
I'm not sure if there'll be an easy way to get to them if they're right behind the pump :(
StefanYHU
1.6 8v
Post by StefanYHU »
Ahh bollox.
Thanks for the reply fella, anyone else any ideas?
StefanYHU
1.6 8v
Post by StefanYHU »
anyone?
poddack
Post by poddack »
12 and 13?
Hmmmm, straight 6 goodness!
I reckon 13 'cos they're right where the pump goes. Not sure what sort of ideas Stefan wants - I presume on replacing the core plugs without removing the HP pump first :?
poddack
Post by poddack »
any photos?
