problem?
problem?
Ive noticed recently this small problem, and im not totally sure whats causing it/what it is
Basicly while im slowing down to a junction/slowing the car down to a stop after a put the clutch in the lights will dim, (not alot) but enough to notice, the engine doesnt stall/cutout but i am starting to get a little squeak from the fan belt so I know that will need changing soon
The two things couldnt be related at all could they?
thanks in advance
Matt
thanks in advance
Matt
Previous Car: S reg 406 SRi 2ltr Turbo - Petrol with 109,000 on the clock
Current Car: Renault Megane 1.6 16v Sport Coupe with 89,000 on the clock
Re: problem?
possibly it could, as the engine slows down the belt does as well, so if its slipping bad it may not be charging enuff
look into changing the fan belts pully tensioner as well , probably worth it why your changing belt,
- rwb
Re: problem?
Re: problem?
Thanks guys
Re: problem?
its normal so ive found out,xero01uk wrote:Thanks guys
youl most probs notice a dip in the fan speed of the heater when this acurs also,
dont worry about it,
Its a Pug thing
Re: problem?
its a pug quirk, courtesy of french elecronics.
Re: problem?
Nah, it's a quirk courtesy of alternators.
Re: problem?
some altenators have regulators to stop that happening
Re: problem?
It's a trade-off, they don't spin at a constant speed and if they generate enough current at idle they'll be frying at full revs, regulator or not.
Re: problem?
in general if a car displays the battery light i assume that means the altenator is done. But what if the car or jeep in question doesnt seem to ever run the battery down.
Re: problem?
thanks for the info guys
Happy New Year
Happy New Year
