Odd noise from rear brakes?
Started the car up to come home from work tonight and as I moved off, there was a loud, repetitve clonk from the nsr wheel. Seemed to be once per revolution, so I stopped to check - everything looked OK.
While braking to a stop, there was very pronounced graunching noise - no doubt rusty discs as it was raining datsun cogs this morning. This noise is normal, but the repetitive clonk? Can you get a pad move with the disc, or a handbake shoe jump like this, anybody know?
Re: Odd noise from rear brakes?
Sounds like it might pay you to get the wheel off and have a good nosey around at the pads/calipers etc. I don't think it can be to do with the inner shoes as you were using the foot brake when it happened - might be worth tugging on the handbrake lightly to see if you can recreate the noise whilst moving slowly just to check?
I wonder if the handbrake shoe had stuck to the drum in all that rain and it was kinda 'catching' for a while?
Not sure but the big worry would be the lining has separated from a shoe and is on the loose in there
Had a similar thing to this on mine sometime ago,especially when
going around right hand bends. Decided time for new pads disc's etc
so bought them dropped them and car off at local garage , when they
finished said the shoes were the reason for the noise as they were
breaking up ....
breaking up ....
I know someone who had a Renault Clito and the rear shoes jammed and locked the wheel
Be careful Doggy.
Be careful Doggy.
As welly says doggy be careful , try parking in gear no handbrake
to see if it is as bad when you pull off .
Thanks guys - to clarify, I wasn't braking at the time, noise happened as I moved off and didn't happen again after first application of the brakes.
It's been OK since too.
And I've been worried sick all day
- Site Admin & Mad Biker!
I'll second this as it happened to me on a motorway a couple of years ago (gawd bless the RAC!)steve_earwig wrote:Not sure but the big worry would be the lining has separated from a shoe and is on the loose in there
Right, now I'm worried.
Converting the garage into a kitchen may not have been doggy's finest hour.
I was on the M6 a bit back and got stuck around J10 in the roadworks
I could here something, so got off at 10A M54 and off aj M54 J1
Jacked the car up, and as you say once per revolution, I had a noise
Took wheel off and disc was slightly warped
Maybe it's as simple as that??
1999 D8.5 HDi GLX - Sold
Bring back my 406
had this problem last year it turned out to be one of the wire pad retaining clip thingummies had snapped allowing the pad to move about
Still OK so far..... I'll hold my breath till Saturday, (60 miles to go).
...and the weather forecast is, 'Chance of rain'.
I estimate about 100% chance.
Ahem....
Guess doggy's going shopping....
Any recommendations? I'm intending to change the discs, pads & handbrake shoes - anything else? which ones?
Oops!
Not as dangerous as it could have been but still pretty serious.
This thread seems to be relevant: viewtopic.php?f=27&t=11621&p=102902&hil ... ay#p102902
Give the calliper sliding pins a bit of love while you're there
