SKY Broadband
plod
Re: SKY Broadband
Post by plod »
typed in admin and password and says authroisation warning
1999 D8.5 HDi GLX - Sold :(
adamr8965
Re: SKY Broadband
Post by adamr8965 »
you typed admin as admin and password as password?
Just go past the warning into the router settings.
1999 1.9 td lx saloon.
plod
Re: SKY Broadband
Post by plod »
yes
this is what comes up
System Authentication Failed.
Please contact your system administrator for the correct information.
Re: SKY Broadband
my old netgear used to let me into its settings the bt doenst really.
adamr8965
Re: SKY Broadband
Post by adamr8965 »
plod who's your isp?
plod
Re: SKY Broadband
Post by plod »
Sky
adamr8965
Re: SKY Broadband
Post by adamr8965 »
Plod your login is admin and password is sky.
plod
Re: SKY Broadband
Post by plod »
ADSL Link Downstream Upstream
Connection Speed 2864 kbps 797 kbps
Line Attenuation 36 db 15 db
Noise Margin 7 db 11 db
adamr8965
Re: SKY Broadband
Post by adamr8965 »
plod wrote:ADSL Link Downstream Upstream
With stats like this you should be getting around 10-12 meg max. You'd never get anywere near the full 20
Now is your router plugged into the master socket with no extension wires? this can slow down the speed. Are you using the correct filters which sky provided?
Theres a good sky forum. www.skyuser.co.uk get some good advice before running sky customer service. If and when you do ring the tech help you need to get to level 2 with has real techie people there. Level one is automatic robots and ou'll get nothing more than unplug it for 10 sec and plug back in.
Re: SKY Broadband
ah yes customer services i recall the time my router broke:
have you tried unplugging it sir?
no my dog knocked it off the table it smashed.
is there power going to the device sir?
no its in 100 pieces the power is going nowhere.
can you plug everything back in sir?
LISTEN the device is broken
i dont understand sir.
the device sat on shelf, dog pull cable, device fall off shelf onto floor, device breaks into many pieces, device is broken.
ah sir i understand, you need to use filters.
NO the device is smashed, kapoot, broken, unrepairable, i need a new one.
ah yes sir you request a new router
yes, how much does one cost?
i shall send you one in the post.
he never awnsered the cost question, i just recieved a new modem and the phone that came with it. Level 2 tech support i assume would be able to understand the concept of being smashed quicker.
Re: SKY Broadband
:cheesy:
adamr8965
Re: SKY Broadband
Post by adamr8965 »
teamster1975 wrote:Image
:cheesy:
Teamster thought Virgin had upgraded their network to 10:1 ratio. Shouldn't you been getting closer to 2 meg upload?
Re: SKY Broadband
adamr8965 wrote:Teamster thought Virgin had upgraded their network to 10:1 ratio. Shouldn't you been getting closer to 2 meg upload?
I'll have to check the config file on the cable modem, I know that they have been phasing in the new upload speeds over the last few months.
plod
Re: SKY Broadband
Post by plod »
Must remember to ring up sky, keep forgetting
checked speeds today a few times and getting worse!!!!
down to 1.5 !!!!!!
plod
Re: SKY Broadband
Post by plod »
was getting paranoid there was a problem with my pc but just downloaded the speednet app onto my Iphone and getting 1.47, so must be the line or service sky is providing
