Mr.Clutch Center's
Mr.Clutch Center's
has any1 ever used a mr.clutch center
think its time for them to do a free clutch test on mine
since i only had fitted 10 month ago and its juddering bad
EDIT - Mr clutch didnt fit it
- Site Admin & Mad Biker!
Re: Mr.Clutch Center's
A mate of mine has used them, they did a good job as far as we could tell & that was a few months ago. £350 from memory all in?
ye sounds about right, think im gonna have to bite the bullet and have another in
only this time pay the real amount and not £180 like the last one 10 month back
its the only thing i hate on my car atm,
- Bailes1992
Dosen't sound like the clutch. XUD cluthes are cheap. Maybe it hasen't been aligned properly? tried changing the clutch cable?
IIRC there are some shockingly bad reviews online
1999 D8.5 HDi GLX - Sold
Bring back my 406
hmmmm really ?plod wrote:IIRC there are some shockingly bad reviews online
yes cable been changed , no change only clutch pedal was lighter and still is lighterBailes1992 wrote:Dosen't sound like the clutch. XUD cluthes are cheap. Maybe it hasen't been aligned properly? tried changing the clutch cable?
http://www.reviewcentre.com/reviews95849.htmlGary406 wrote:hmmmm really ?plod wrote:IIRC there are some shockingly bad reviews online
Bring back my 406
now im not going to Mr clutch after all
I guess my mate was bloody lucky then!
Edit: Actually one of the only good reviews was for Slough branch which they used. Phew!
not all people will be un happy,
you cant please every1
- Bailes1992
I reckon the clutch hasen't been aligned. I have the same problem with my Focus. But it only happens when you come off the clutch slowly around 1200rpm. If you bring the revs up a little and come off the clutch abit quicker than normal it's fine and perfectly smooth. Just took abit of gettign used to.
ye i have exact same thing
if i rev to 2k or even 1.5 and let clutch out slightly faster its smooth .....
so its bad allignment
Aligment is only an issue when fitting the gearbox back in, when the clutch is pressed once there is no issue, of course the clutch could get damaged forcing the gearbox back in.
There could be a problem with the pressure plate not being tightened evenly, lack of correct lubrication on the gearbox spigot shaft, incorrect cleaning of the pressure plate surface before fitting (not degreased properly), or the bearing slide not cleaned/lubricated properly....or any number of other reasons, including a faulty clutch.
- Nicodemus
Exactly what Jasper said.
And if you're not prepared to cough up a few quid extra to get the job done properly then... Well you'll likely have problems.
True mine's a D9Hdi, I got 3 quotes for a new clutch and the best was 399 from the local stealer! Day's work, what with splitting drive shaft and dropping everything out the bottom. But it's lasted a good few miles so far, mustn't grumble...
52 HDI(90) 406 saloon. Sadly no longer owned, bless her she got near 200,000 miles and I had to sell her on, she was still going strong.
Airfix test pilot and part time formula 1 driver for scalextrix
