fitting reluctor rings
can someone advise me weather i have to remove the drive shafts of my 2002 90 hdi to fit new abs reluctor rings or is it possible to pull the hubs of the shafts and do them like that?, cheers.
Re: fitting reluctor rings
I don't think you need to completely remove them, although you'll have to get them out of the hub which is some fairly major surgery. Did you find the how to over on the coupé club?
thanks steve, went over to coupe club and write up explained it all. just waiting for my new reluctors from parts direct, £14.99 each + p+p. will try to fit them this weekend. cheers again.
No problem, best of luck!
