Taking off valve caps
DiscoPol
Shiny New C5 2.2 Bi-turbo!
Re: Taking off valve caps
Post by DiscoPol »
Welly wrote:Bit early for you isn't it? have you had your coco-pops yet?
I had a free lesson this morning so thought I would use the time constructively and prepare for the rest of the day, alas all I did was have a bloody good browse of 406oc, I'm starting to think the oc stands for "obsessive compulsive" though, Mr Earwig is in full Pedant mode again I see :P :wink:
Yes, I find myself spending longer than I should on here, for example; earlier I spent a good 6 minutes staring at your avatar and wishing I was there :supafrisk:
DiscoPol
Post by DiscoPol »
have you noticed some lucky bugger is pouring more baby oil on half way through the "pull up" just to help lower any friction?
I frequently wish i was said lucky bugger :lol:
no2lurch
Post by no2lurch »
Welly wrote:Sounds like a case of galvanic corrosion between dissimilar metals and their (ref: spelling nazi corrective) respective electrolytic ions. You must introduce a control by the addition of a sacrificial anode affixed to the alloy wheel perpendicular to the corrosive elements. I suggest you braze a length of Table-Y copper tubing adjacent to the valve cap, approximately 150mm in length and untreated. A simple earth-conductor may also be introduced to accelerate the process - this will require you to fit a ground-earth spike (made from 100% brass) and ground each wheel every time you park you vehicle - you could perhaps introduce a quick-release (non corrosive) electrical connector to help speed things up if you're in a hurry.........
i work for a corrosion control company - i suggest and Impressed Current Cathodic Protection system! or plastic caps!
Current car - Ph3 1.8 306
chemistry wasnt a subject i liked at school. But i did understand physics, ill cut off the valve caps, and put on the plastic ones.
robb
Post by robb »
.......either that or buy some bloody plastic ones :roll: :lol: :lol:
never mind all that palava do without
i find it very hard not to stare for some time at discopols sig.
Bailes1992 wrote:May I take this opportunity to mention the fact I have no issues with my plastic ones? :roll:
same here plastic ones are the best
DiscoPol
Post by DiscoPol »
FarmerPug wrote:i find it very hard not to stare for some time at discopols sig.
if that is sig material i dont know what is :lol:
oh and she does look fine, doesn't she?
Im not looking @ that avatar its very pervy to do that lol,
And for all we know it couid be a Dude :lol:
DiscoPol
Post by DiscoPol »
if its a dude, he has a cracking arse!
DiscoPol wrote:if its a dude, he has a cracking arse!
lolol, you never know these days . :|
My mate was eyein a bird up out side a bar ithink he thrown up for about a week later /after he found out Brenda was Actualy called brendon.
iclocked it but let him Go with the flow as he thought he pulled the bird of the Centuary , :lol:
DiscoPol
Post by DiscoPol »
If you don't check then you deserve everything you get these days, if it is a bloke called Brian, then you would definitely get more than you expected :lol: :lol:
I refuse to comment as some people on here are trying to stereotype
me as a pervert , when in fact i am just an admirer of the female species !!
mine are plastic by the way :)
puggy wrote:I refuse to comment as some people on here are trying to stereotype
How come theyre calling you a perv mate ?
Theres no porn on the forum is there :P
