Not so long ago I had to replace my positive battery terminal as the old one had actually split & was only just in contact. Unfortunately I made a bit of a bodge solution & fitted a clamp type terminal thinking it would do. Having had a closer look, I'd really rather put the proper job on there, but I'm not overly sure which terminal to get or how to fix it to the wiring.
I think I'm supposed to have this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
But £20 seems a bit overpriced to me. Have contemplated getting these:
http://cgi.ebay.co.uk/BATTERY-TERMINAL- ... 3a62b0c9b6
But I'm not too sure how or where the wiring fits to them.
Can anybody send me a link to somewhere that I can get the proper terminals for my battery without paying an extortionate price please?
Battery Terminals
- waue1978
- HDi don't believe it!
Battery Terminals
Re: Battery Terminals
The wires go into ring connectors that are clamped inside the terminal.The add should say "From the 1970s"
I wouldn't know where to buy something like that there any more (tried GSF, Pugspares etc?) but the real thing comes with the cable and costs a staggering £87.52
Rescue one with a good 'battery end' from a scrappy and graft it onto your existing cable?
- jamjar1383
u do know there both for renualts dont u??waue1978 wrote:Not so long ago I had to replace my positive battery terminal as the old one had actually split & was only just in contact. Unfortunately I made a bit of a bodge solution & fitted a clamp type terminal thinking it would do. Having had a closer look, I'd really rather put the proper job on there, but I'm not overly sure which terminal to get or how to fix it to the wiring.
d9 hdi 90 rapier estate
how about these http://cgi.ebay.co.uk/CARAVAN-MOTORHOME ... 53e22e885d
says caravan but the quick release look good on them and a nice tidy cover too
- waue1978
They're advertised as being for Peugeots. Ordinarily I would've thought the terminals I have would be fine, but the terminals on my battery (& hopefully other 406s) are narrower at the top than they are at the base.jamjar1383 wrote:u do know there both for renualts dont u??
They look ok actually. Nice & easy to fit too - as long as they'll fit ok.lozz wrote:how about these http://cgi.ebay.co.uk/CARAVAN-MOTORHOME ... 53e22e885d
I used these http://motors-parts.shop.ebay.co.uk/Oth ... als&_rdc=1 because when the "quick release ones " bit on the battery breaks it`s a pain in the arse cos connection isn`t good or erratic at worst , get these others and it stops all that and you know for sure it`s connected , a smear of vaseline helps if battery is prone to corrosion although the cover should help prevent that .waue1978 wrote:Not so long ago I had to replace my positive battery terminal as the old one had actually split & was only just in contact. Unfortunately I made a bit of a bodge solution & fitted a clamp type terminal thinking it would do. Having had a closer look, I'd really rather put the proper job on there, but I'm not overly sure which terminal to get or how to fix it to the wiring.
I found them dead easy to wire up btw. and they`re cheap and quick to deliver (post free)
Replacement !
- waue1978
That link came up with just a list of batteries & couple of terminals. Did you mean these?Archangel wrote: I used these http://motors-parts.shop.ebay.co.uk/Oth ... als&_rdc=1 because when the "quick release ones " bit on the battery breaks it`s a pain in the arse cos connection isn`t good or erratic at worst , get these others and it stops all that and you know for sure it`s connected , a smear of vaseline helps if battery is prone to corrosion although the cover should help prevent that .
http://cgi.ebay.co.uk/Pair-Clamp-Type-C ... 53e5ab7f14
That is what I have on the +ve side at the moment, but they don't really fit properly due to the tapered terminal.
yes, it is for a renno and yes it's the right one, i got one from a scrappy near me.
Hmmmm, straight 6 goodness!
