I have an R Reg Peugeot 406 1.9DT Estate, it has Aircon and a bosch fuel pump (if that is relevant) the belt tensioner for the alternator is knackered (flapping about) and needs replacing.
Places like GSF and Eurocarparts seem to list between 3 and 10 polley belt tensioners for this model with absolutely no clue as to how to tell which one I need.
Its the tensioner that you can see obviously between the alternator and the engine block.
From GSF (http://secure.gsfcarparts.com/shop/results.asp) there are 3 tensioners listed for the 406TD+Aircon:
135PC0010 RIBBED BELT TENSIONER 406 1.9TD + AIRCON £73.00
135PC0090 RIBBED BELT TENSIONER 406 1.9TD + AIRCON £45.00
135PC0100 RIBBED BELT TENSIONER 406 1.9TD + AIRCON £43.70
Can anyone tell me which one I need as I want to get it replaced ASAP.
Which belt tensioner. 1.9DT
- highlander
- PowerFlow Shill
Re: Which belt tensioner. 1.9DT
Is there a part number printed on the belt you've currently got?
Its the tensioner I need rather than the belt.
And it will have a Peugeot part number that doesn't relate to the GSF/Eurocarpart part numbers.
i had mine changed bout 2 months ago.... it was £70
not much help. the guy at general traffic didnt tell me there was different ones ...
Your parcel shelf sounds amazing, mines only a D8.Gary406 wrote:i had mine changed bout 2 months ago.... it was £70
eh?DrDoctors wrote:Your parcel shelf sounds amazing, mines only a D8.Gary406 wrote:i had mine changed bout 2 months ago.... it was £70
