New tyre on and running perfectly again.
30k on and I have a similar problem, only this time the tread wear is completely even, about 3-4 mm left all over, but if you run your hand round the tread, close to the inner shoulder, you feel a high spot every 4 or 5 inches.
I had thought the resulting noise was a wheel bearing or similar, but having swapped the spare on, it's silent and the little bit of steering shake I had is gone too. All good news, but obviously I don't want to repeat the problem a bit further down the road.
I know the rear camber is adjustable, but I don't think that's the issue here, the tread wear is too even. Some stuff I read on the coupe forum suggests the rear tracking is also adjustable, so anyone know what adjusts it and how to set it up correctly. (By which I don't mean letting Kwik Sh1t or similar blunder around making it worse, or allowing the Pug dealer to recoup some of the money they haven't been able to extort from FAP-equipped owners recently).
