This Focus is bloody strange...
Bailes1992
Post by Bailes1992 »
I HAVE A WOBBLE!!!!!!
And it's really fustrating.
70mph+ I have a wheel wobble. The wobble dosen't go away with speed, it dosent get faster or slower with speed. It gets harsher with cornering and speed but it never gets faster.
Last night I was going down my private road at a smidge over 100mph and I saw traffic ahead... on my private road. I touched the breaks and I got a low pitched "Duddududududududududududu" from my front drivers side wheel. The beats were at the same frequency as the steering vibrations. So I assume there related.
My front wheels are 100% balenced and not buckled at all.
I have changed my inner and outer trackrods on both sides as they had play.
I've had full wheel alignment done.
Swapping the wheels about dosen't make a difference.
I have fitted all new discs and pads which made no difference.
I come here to ask because your able to have a discussion about it, most other forums people keep saying what popps into there head without reading my post and dissapeer.
I have been told many many times I have out of balence wheels :roll: When I don't.
Brainstorming session please? At my wits end with this bloody vibration.
Bailes.
Re: This Focus is bloody strange...
My guess is on a sticky caliper reason why is because you say you touched the brake before it happend,
oh and slow down fella youl end up thru the windsceen u daft sod :roll:
On two occasions my 406 has had similar problems with a balance-like vibration, apparently from the front. Both times it's been due to a mis-shaped REAR tyre! (I refused to beieve it too).
Had a slightly similar problem years ago with a Montego, that turned out to be a tiny bulge on a front tyre.
Met some unexpected traffic on my private test track the other night too - was that you Simon?
Bailes1992
lozz wrote:My guess is on a sticky caliper reason why is because you say you touched the brake before it happend,
It's been happening since I've had the car, it's not related to the brakes at all.
When I touched the brakes my front wheel mades a "dududududu" sound at the same frequency as the vibrations I'm getting through the steering wheel.
Bailes1992
dogslife wrote:On two occasions my 406 has had similar problems with a balance-like vibration, apparently from the front. Both times it's been due to a mis-shaped REAR tyre! (I refused to beieve it too).
I wonder if I have a problem with a rear wheel? I stuck Bernards wheels on the front of the Focus just to see but it was still there. :|
if your on the Anchors coming down from aton the brakes will make a racket,
if you want something that wont fade or let you down an upgrade is the way forward focus brakes standard ones are shite just like mondeo ones, ive burnt several sets out ,
try stopping at normal speeds ibet you dont get any problems then.
im not having a dig mate but dont expect standard brakes not to let you down as they will :roll:
Bailes1992
Didn't slam on mate, I touched the brakes very slightly just to slowly bring my speed down. I never slam on on my private road:), Infact I try not to touch my brakes all together.
arh was it a thud thud felt thru steering wheel and pedal .... its the Abs kicking in yo
Bailes1992
lozz wrote:arh was it a thud thud felt thru steering wheel and pedal .... its the Abs kicking in yo
No ABS yo :roll: :lol:
must be a low poverty spec then if its not got Abs,
mondeo had it standard even lxs :?
iworked on a x plate focus not long back lx that had abs
Bailes1992
lozz wrote:must be a low poverty spec then if its not got Abs,
It's an LX. My Dad had a V reg Ghia Focus saloon (granded spec) with the 1.8 TDDi lump. That didn't have ABS either.
jamjar1383
Post by jamjar1383 »
warped disc??
d9 hdi 90 rapier estate
Bailes1992
jamjar1383 wrote:warped disc??
Brand new discs, had to change them as the old ones were warped. The vibration is constant, not just when I put my foot on the brake.
Only things I can think of are the CV Joints and the Steering rack?
CV joints dont usually cause vibrations . to my knowledge anyway.
do the brakes not feel as tho they are sticking slightly ?
have you been over it all checking for loose bolts (highly unlikely) but worth a look ?
Bailes1992
Gary406 wrote:CV joints dont usually cause vibrations . to my knowledge anyway.
Brakes are fine :|
Everythings tight, no loose bushes either etc.
