Is It Head Gasket ?
Roylewaa
Re: Is It Head Gasket ?
Post by Roylewaa »
If your heaters are fine Gary, and if the cars done that since you changed the sensor it could well be the coolant levels settling down or an airlock, try topping up and running it up to temp with the coolant cap off to dispel any airlocks (keep an eye it doesnt boil over as if the coolants not under pressure it will boil over, check for any obvious leaks especially around the replaced sensor (small ones are hard to find on a hot engine) so check for marks from burned off coolant) whack some k-seal in for good measure, fill her up with diesel and go from there
D8 2.1 TD saloon, oh yeah :)
thanks for the input guys. my mind is at ease a bit now. been told its not likely to be HG . but will keep a good eye on it over next few weeks.
greebo
Post by greebo »
Hi, my Brother in Law used Steel Seal in his Renault Clio about 2 years ago and it's still going strong. He was told by the Motor Factor to follow the instructions to the letter ! He reckons it's the best £30 he's ever spent. kev
ok cheers mate will keep that in mind. i'm gonna try the k-seal 1st it gets good reviews online. lets hope their all telling the truth, :shock:
well. panick over.
found my water leak. after changing the coolant sensors i thought it could be them. found coolant all around the bottom of the thermostat housing.
so took sensors out and put PTFE tape on the threads. .
after that still had water under the housing. i dried it all fully then started engine and water is seeping out the thermostat .
so it needs a new thermostat cos the seal has gone. i took thermostat out and cleaned the rubber seal.put it back in a different way and its still leaking :evil:
Roylewaa
Post by Roylewaa »
I'm pleased you've a least found the leak and its not going to cost you the earth to put right
I thought it might of been something to do with that area :)
ye im pleased as well mate. didnt wanna get rid of it.
i put PTFE tape on to make sure it wasnt them before removing the thermostat and loosing half my coolant.
anyway the quick fix didnt work - putting thermo in a different way. so ordered a new one just now off euro car parts.
will change it when it arrives and top up with ready mixed coolant.
Roylewaa
Post by Roylewaa »
That ready mixed stuff will be ok now winters out the way, but its usually pi$$ water, I would flush and do a 50/50 mix when it starts getting really cold again
Bigcol
Post by Bigcol »
I had the same thing on my thermostat housing... i put a thin smear of silicone around the housing before nipping it up and never had a problem since.. apart from a mahoosive hole in the head gasket of course!! :lol: Im glad its not your Hg!
i will probably put a bead of silicone around it when i fit new thermostat.
altho with a new stat it shouldnt leak. i changed the housing last year because it was warped so unless thats happened again it should be ok without silicone.
now i have a bottle of K-SEAL that i dont need. general traffic parts will not take it back because its under the fluids & liquids policy. non returnable :evil:
andymacg
Post by andymacg »
keep it in the motor gaz you never know when you or someone might need it, ive got one in my tool case just incase
jolly green giant 1.8 16v LX estate
ye will do mate cheers.
its not as tho it cost a fortune anyway :mrgreen:
well the HG panik is over. i went for some K_SEAL . when i returned home i was shaking the bottle and spoted coolant seeping out the thermostat
a new thermostat fitted today and the leak has stopped :mrgreen:
plod
Post by plod »
Good result Gary 8)
1999 D8.5 HDi GLX - Sold :(
cheers dave. all i can think is that the white smoke was from the veg oil burning clean :?
i even got a refund from euro car parts for the thermostat that started leaking. i only bought it in febuary.
