Lower engine mount,
Re: Lower engine mount,
can you get me a price john for both engine mounts on mine.
gearbox side and top drivers side.
jasper5
Post by jasper5 »
Gary406 wrote:can you get me a price john for both engine mounts on mine.
There is a mount and a stabiliser bar at the driver's side and a gearbox mount with 2 bolt holes and a large hole in the middle if yours are that type.
Each are £25 including vat (trade price).
kev1839
1.6 8v
Post by kev1839 »
StevieboyTD wrote:"easier" method, cut out the old unit by taking segments out of the metal ring, then get this http://cgi.ebay.co.uk/PFF50-306-POWERFL ... 1c18846e9a same block and mount as the 1.9TD engines, but it's a 2 piece polybush, so no hassle trying to press it into place under the car.
kev1839
1.6 8v
Post by kev1839 »
[quote="StevieboyTD"]"easier" method, cut out the old unit by taking segments out of the metal ring, then get this http://cgi.ebay.co.uk/PFF50-306-POWERFL ... 1c18846e9a same block and mount as the 1.9TD engines, but it's a 2 piece polybush, so no hassle trying to press it into place under the car.[/quote
Have been reading this with great interest, sounds a good way to overcome a big weak spot on the 406. Sorry StevieboyTD for seeming a bit thick but does the 306 polybush fit the 406 HDI ?? I note you have a 1.9 TD so are they the same Size mounting ? looking on e bay it seems as if they are just wondering if you know :D
marco2002
Post by marco2002 »
Hi
That 2 piece powerflex bush would it fit a 2.0 hdi as well?
StevieboyTD
Post by StevieboyTD »
From what i know the mount on the back of the engine is the same size on the XU & DW10 blocks.
2.1td exec estate.
kev1839
1.6 8v
Post by kev1839 »
StevieboyTD wrote:From what i know the mount on the back of the engine is the same size on the XU & DW10 blocks.
Thanks for all your info will order one from e bay and let you know how i get on :D
