rear windows
APR
rear windows
Post by APR »
Hello, my rear glass don't open or close very well, they are very slow, sometimes stops in the midle of the window.
Can anywan help me ?
Re: rear windows
Hi mate,
Might be the runners for the glass you be best to pop the door card off and have alook whats making it tight,
but id try spraying some silicone spray ~ down the window seals 1st or washing up liquid ive done this in the past on some cars and its helped.
it sometimes happens if the window hasnt been used much,
hope this helps if any,
APR
Re: rear windows
Post by APR »
lozz wrote:Hi mate,
So i have to take this write ?
And how I stick this again ? what is a spray silicon ? is lubrificant in spray ?
sorry but I don't speak english :)
Re: rear windows
APR wrote:
lozz wrote:Hi mate,
your english isnt too bad infact its better than mine so dont worry about it :lol:
take the seal off the door carefully if it does not come of easy try warming it with a Hair dryer so the glue softens abit,
once thats off look at the runners and see if anything is out of place,
silicone spray is a Lubricant other things such as them dash board shine sprays in a can as it in too so that can be used,
or use some Fairy liquid or any other washing up liquid dont use anything with oil in tho as it will be a pain to get off the glass,
DiscoPol
Shiny New C5 2.2 Bi-turbo!
Re: rear windows
Post by DiscoPol »
The rears seem to become lazy without much use, i did the silicone trick and just started to use them everyday at least once a day and they became quicker and easier with time.
HTH
APR
Re: rear windows
Post by APR »
lozz wrote:
APR wrote:
lozz wrote:Hi mate,
ok thacks a lot, but how I stick again the think I take ? with wich glow ?
other question, I can lubrificate with WD40 ?
Re: rear windows
hi mate
do you mean How do istick the seal back on the door again?
if so any ordinary silicone will do or tape it on with ducting tape :wink:
please feel free to ask what im going on about if you cannot understand my english and bad spelling :oops:
Re: rear windows
Also Wd40 is fine but avoid getting it on the glass it will make a mess, :roll:
APR
Re: rear windows
Post by APR »
lozz wrote:hi mate
ok ok i'll ask :D yes but what silicone ? can you tell me brads ?
Re: rear windows
APR wrote:
lozz wrote:hi mate
Any household silicone wouid do preflably black if you can find it or clear,
any do it your self store wouid be able to provide that,
or if you have motorist shops near you you couid ask for something called Tigerseal or sikaflex idont know if these are avaiable in your country tho thats why i mentioned silicone sealant ,
hope that helps if any
sorry icannot suggest anyproducts your familiar with as idont know what they use in your country ,
APR
Re: rear windows
Post by APR »
lozz wrote:
APR wrote:
lozz wrote:hi mate
Thanks, I'm from Portugal. If we don't have the tigerseal for example , I'll buy in the internet ;) Thanks man , thanks a lot
Re: rear windows
tigerseal definatley is the stuff to use here, i used silicone first it was no good, nor was no more nails, tigerseal worked great.
