Auto volume, ?
Auto volume, ?
hi all,
whats the Auto volume for on the D9 radios, ?
when igo to switch it on it does nothing,
is this function for petrols to cut out road noise hence why it wont work on mine ? :?
Everything else works just this,
thanks inadvance,
Re: Auto volume, ?
No, it should increase the volume with road speed.
Re: Auto volume, ?
dogslife wrote:No, it should increase the volume with road speed.
cheers mate,
Mines dont work it just stays on "off" whatever ipress ,
Re: Auto volume, ?
You should be able to change it with the buttons above / below the one you selected the option with. :?
Try removing the permanent supply from the head unit to reset it?
Re: Auto volume, ?
dogslife wrote:You should be able to change it with the buttons above / below the one you selected the option with. :?
cheers mate,
ive tried that and still it dont work,
its not something ineed to work its just something iwas wondering what its for kinda thing,
thanks tho
grasmere59
Re: Auto volume, ?
Post by grasmere59 »
Mine does'nt work either so i've given up trying,i've got it in my Boxer van and it is quite handy but it won't work in the 406 :(
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: Auto volume, ?
Ive always found it a gimmick.
Even with the casette player it never made much of a difference. It was the same in my dads car, and the new hilux.
RayneR
Re: Auto volume, ?
Post by RayneR »
Well, awkward is that i have the cassette player and CD changer in the boot but my auto volume doesn't work too ... strange thing because all of them have it , i even saw in the peugeot planet that it doesn't work/have/or is disabled this function, i didn't had the time to go deeper into this , but here it goes :
13 - 3 - AUDIO SYSTEMS
New RM2 model radio, made by CLARION with cassette player in the front panel .
New RD2 model radio, made by CLARION with CD player in the front panel .
This audio equipment is fitted with the automatic speed-related volume adjustment function .
These audios are able to run a cd player .
In service, the audio equipment and the multifunction display (B or C) must be configured using the DIAG 2000 (This function will become available during the course of the year) .
The amplifier JBL is available as an option on estate versions .
The role of the audio system amplifier is to give better reception and sound quality .
The amplifier JBL is secured to the satellite navigation system ecu support .
This was taken from a technical CD from peugeot ...
2000/May 406 Estate 2.0 HDI 110bhp DW10ATED now with 205k km & now with cruise control & now remaped @ 134bhp :lol:
Re: Auto volume, ?
ive been looking into this but icarnt work out which wire sends the speed signal,
theres no decent diagrams for the d9s,
im waiting to see amate of mine that wires up taxi meters in 406 taxis then hopefully he will tell me which wire to check see if its disabled ,
its all downto speed signal ithink but icouid be wrong
iasume this will be connected to petrol models but not dervs ( confused dot com )
Re: Auto volume, ?
what can i do about making a cd player work right with the jbl amp, the clarity isnt as good as it used to be.
Re: Auto volume, ?
FarmerPug wrote:what can i do about making a cd player work right with the jbl amp, the clarity isnt as good as it used to be.
idunno tbh mate,
Maybe if youve had an aftermarket stereo fitted it may have took some of the quality off the speakers,
the ones in mine are Harman not jbl but spose there the same make Kardon,
but as far as ican see there only rated 30 wat ish so some aftermarket stuff wouid loosen them up abit,
Maybe its just a case of getting used to the sound of the original stereo again ,
Re: Auto volume, ?
Im really planning to put the original one back in, just need to spray it the same colour as the rest of the dash first, i remember the sound quality was much much better, and the volume could go into the AAAAHHHHHHHH MY EARS ARE BLEEDING loudness at about 20, now i can listen to 30 ie max and its quite bearable.
Re: Auto volume, ?
FarmerPug wrote:Im really planning to put the original one back in, just need to spray it the same colour as the rest of the dash first, i remember the sound quality was much much better, and the volume could go into the AAAAHHHHHHHH MY EARS ARE BLEEDING loudness at about 20, now i can listen to 30 ie max and its quite bearable.
Ihave mine on full bass loudness function on,
they dont rattle sounds pretty good one of the reasons why im leaving it as it is,
if ithrow a aftermarket one in itl never sound the same,
ijust need a cd changer im getting fed up with key 103 :lol:
Re: Auto volume, ?
That was the thing this is the new radio, bass treble and loudness and volume at full whack is still only half as good as the old radio with none of the options on at 20.
I used to keep it 10 with just the loud thing on, it was really good, especially with classic fm, pavorotti is a good test for a sound system he soon finds any rattles.
Re: Auto volume, ?
FarmerPug wrote:That was the thing this is the new radio, bass treble and loudness and volume at full whack is still only half as good as the old radio with none of the options on at 20.
Pavarotti :?
are you sure you dont mean Prodigy.. iMa Tawisted fire starta and all that :twisted:
