2000 hdi aircon problems!
mbradshaw2820
Post by mbradshaw2820 »
hi i have a 406 hdi and have just had the aircon condenser changed and system regassed, aircon worked fine that day but now wont kick in. system is holding pressure and if i put a feed to compressor it clicks in and out. have checked all fuses and are ok. autodata tells me there is an aircon relay behind fusebox under steering wheel and after a lot of sweaing and time i cannot find it. please please someone help me!!!!!!
mbradshaw2820
Re: 2000 hdi aircon problems!
ok so ive now spent all night tracing the compressor wire into the cat testing at points along the way. it goes into a unit under the fuse box which i believe is the bsi unit? if i dissconnect the connector which has the compressor wire in it i can power up it and it clicks in, if i test pin out unit it shows positive although a bit faint. but if i reconnect the wire shows negitive!!!! is this the bsi unit at fault???
There's a good chance the aircon compressor control relay, (in the BSI), is your problem. I have once seen a post about changing this relay, but can't remember whether it was on this, or the 406 coupe forum.
Try a search for 'BSI relay', 'BSI repair, or similar.
Could be worthwhile looking at the 2 resistors and relay that sit
at the side of the fan , the resistors are known to rot . When i
replaced mine everything suddenly worked .
steve_earwig wrote:Here it is on the coupé club: http://www.peugeot406coupe.com/phpBB3/v ... e7337c62a4
Once more in French: http://www.coupe406.com/Forum/viewtopic.php?p=353817
Well done young Wiggy! - When do you set off for your little trip, BTW?
(Good luck, whenever it is). :mrgreen:
