fuel pressre
fuel pressre
Just like to know, what bar fuel pressure regulator do I need for my '99 Hdi 110 turbo diesel ? Cheers Steve
Re: fuel pressre
It doesn't have one, Steve. There's a sensor the ecu uses to measure rail pressure, it's regulated by controlling the HP pump.
Re: fuel pressre
So what is that device in the fuel return pipe that looks like a regulator then ??
Oh yes, and where is the throttle body hiding, thought it would be between intercooler and inlet manifold, but can't find anything.
Also how can it open and close as the TPS and cable isn't attached to anything !!!???????
Re: fuel pressre
No throttle / body either.
Re: fuel pressre
diesel = no throttle
Hmmmm, straight 6 goodness!
