which 406 ?
Re: which 406 ?
the comm2000 doesnt worry me TBH. a 52/53 plate 2.2 is sounding good remapped to 180bhp...
it all depends on what is for sale at the time of me buying and the price.
ive been looking at 2.0 110s executive which are still very nice motahs and the 110 could be remapped to 140 which will be fine for me....
Re: which 406 ?
When looking at a 110 try to secure a 45+ minute test drive (offer to pay for the diesel if it helps) and get the transmission good and hot - then watch carefully for clutch slippage when pulling hard through 2000 rpm in 5th. Any slippage will be known about by a private seller and will provide a nice bargaining tool - the 'problem' is not that big a deal and can be lived with (as standard 110bhp).
Re: which 406 ?
cheers welly will bare that in mind
what causes it to slip in 5th around 2000rpm ?
Re: which 406 ?
It slips due to a worn DMF/Clutch combo but only presents itself after a good bit of use, great if your a seller - not so great for the buyer on the way home......
Another tell-tale is a loud chirp/squeek as soon as the engine fires up and when coming on/off the clutch sharply.
All HDi's appear to have a silly-high biting point and high pedal but that seems 'normal'.
Re: which 406 ?
ok thanks welly some good pointers to bare in mind there..... if im paying 2k for a 406 i will indeed be testing it for a good 45 mins and doing the test you told me to do .. cheers :)
Re: which 406 ?
sometimes not all i get the dmf squeak when setting off usually in the cold but it didnt affect driving. still better to get a solid conversion if possible
also the hdi has a cover over the engine the clips are utter poop so just replace them with bolts but what happened with my car was the dipstick kept coming up and i thought i had HG faulure on the way luckilly the cover vibrates and just pushes it up.
Re: which 406 ?
If you're considering a 110 with a 140bhp remap, it might be worth noting that poor Lozz had to get his gearbox changed at 120k as it couldn't handle the extra grunt. Had been considering it myself until I saw that.
Re: which 406 ?
well that settles that then 110 bhp my car will stay, its no ball of fire, but it doesnt use any oil or water and you dont hear of turbos blowing so its a fairly durable engine.
Re: which 406 ?
has the 110 got a good pull.... if u know what i mean
Re: which 406 ?
waue1978 wrote:If you're considering a 110 with a 140bhp remap, it might be worth noting that poor Lozz had to get his gearbox changed at 120k as it couldn't handle the extra grunt. Had been considering it myself until I saw that.
Bear in mind my gearbox is OK. Is it not a BE-series gearbox issue?
IIRC, 405 1.9D & TD gearboxes weren't bullet-proof, wouldn't Lozz's HDi have a BE3 too?
v6's, 2.1's, 2.2's & later 110's are all ML5's, (I think).
Re: which 406 ?
so is it the early D9s that have Be Gearbox ?
how do you tell which have BEs and which have ML5s ?
Bailes1992
Re: which 406 ?
Post by Bailes1992 »
The 306 HDi's have been run with 160bhp + with no effects other than having to fit an aftermarket clutch.
I assume Lozz's gearbox was maybe abit worn in the first place.
Must stop looking at this thread... your making me want a 406 again and I've already decided it's a bad idea :lol:
Re: which 406 ?
:mrgreen: :mrgreen:
well if it helps same i will be definately getting a new exec D9 in a few months.
even considering going to the more sporty looking coupe . . .
Bailes1992
Re: which 406 ?
As much as I really really want another 406 I begrudge paying an extra £400 a year for a HDi 110, £120 a year for a HDi 90, £370 for a 2.1TD and £80 for a 1.9TD :|
But If I find the Perfect Exec or SE then I may may mayy have to raid the piggy bank :oops:
Re: which 406 ?
the hdi 110 has plenty of pull hitch a trailer and off it goes i put on a trailer with my jeep on top and the 406 pulled it nicely.
did lozz get his car remapped or was it done before it came
