We use the USB port for looking through holiday pics etc, just plug the camera straight in and start the slideshow!FarmerPug wrote:thanks for the suggestion
http://www.solwise.co.uk/net-powerline-pl-85pe-mk2.htm
would this work if the house is on the end of a terrace?
how long does it take to start these up, say it gets unplugged and turned on again will it establish a connection again instantly? And is a single pack just one (what can you do with one on its own?)
But im still liking the idea of the Wireless bridge its just £20 and it should get good signal because the routers only about 4 metres away from the tv and all other wireless devices get the full signal when beside the tv.
On the usb port, i had a play with it last night, i did manage to view some pictures on a slideshow with it, it was amazing the quality of the photos on a 40inch screen and they had only been taken with an iphone.
The single packs are to add extra plugs into the network, there's no point buying one on its own unless you already own 2
Start up time is almost instant, about 5 seconds after switching on, and you can set a password on the units so that people in the terrace can't plug in and use your network
