Bit of an odd one here, I've had the 406 running on veg now for a good couple of months with no problems, I change the fuel filter regularly (last done about 300 miles ago) but I ran into a very strange problem today.
It took quite a bit longer to start than usual (needed 3 rounds of the glow plugs) but once was running I assumed it was fine, however after I'd driven down the road and went to pull up to a set of traffic lights, the engine completely cut out as soon as I dipped the clutch, and it wouldn't restart no matter how many times I put the glow plugs on. Somehow moving it on the starter motor seemed to then get the engine to restart when I tried again, but before that it didn't even sound like it was trying to fire!
Has anyone got any suggestions as to what might be causing this? As I said, the fuel filter has been changed very recently. A bit panicked as I was supposed to be taking the car to Yorkshire this weekend!
Cheers,
James.
Edit: Also, to anyone who doesn't know, it's had a Bosch pump conversion
![Smile :)](./images/smilies/icon_smile.gif)
