Passat 4motion TDi?
sirwiggum
Re: Passat 4motion TDi?
Post by sirwiggum »
The TDi in the Bora and the Passat is the same engine is it not?
As also seen in Octavias etc. and blowing a turbo in an Ibiza.
406loon
Post by 406loon »
Best VAG stuff is Fabia vRS, Seat Ibiza Cupra PD160, Leon Cupra-R 225, Leon Cupra/FR PD150, Octavia vRS petrol and diesel, Superb mk1 and mk2. You only need to look at the customer satisfaction surveys like JD power/warranty index etc to see which is the top VAG brand for relibaility, value for money, build quality - Its not Audi, VW or Seat either.
53' 406 2.2 HDi SE saloon - Samarkan Blue
Coupe strut brace-BMC CDA-Bosch Aero wipers-2.5'' T304 fap back exhaust-de-cat/dpf internals-EGR blank-180bhp remap-Ultra Racing rear lower brace-Poly engine mount- Brembo calipers-braided hoses-LEDs-55w Xenon 6k kit-nightbreaker plus main+fogs-LED sidelights
sirwiggum wrote:The TDi in the Bora and the Passat is the same engine is it not?
yup they can be the same,
theres a few differnt lumps in them,
the Boras ive driven have been pd 130 engines,
there used in audis too
Bailes1992
Post by Bailes1992 »
http://www.autotrader.co.uk/classified/ ... ?logcode=p
I do like that too, lovely looking car :)
Fancy the AWD system.
bailess buy my golf gt tdi :mrgreen:
sirwiggum
Post by sirwiggum »
Bailes1992 wrote:http://www.autotrader.co.uk/classified/ ... ?logcode=p
You may wish to print thisout, and stick it to the dashboard if you buy one of those.
Bailes1992
Only reason I'd go for something like this over a 406 is simply for the AWD system.
sirwiggum
Post by sirwiggum »
ally406 on the MOT thread wrote: My neighbours 56 plate passat has just been towed home for the third time with it's third injector failure. Each time he's had to fork out £500 for a single injector. I told him his fancy German barge was too complicated and he should buy an old French heap instead. He didn't seem to see the funny side :supafrisk:
Reliable? The Ultimate Marketing Machine.
Bailes1992 wrote:Only reason I'd go for something like this over a 406 is simply for the AWD system.
'cos it's just sooo useful :roll: Well, perhaps for towing your mate's cars out of ditches...
They're not actually 4wd in the way we'd like to think, they 'become' 4wd only if the front wheels loose grip so other than driving on wet mud or snow it's pretty much a FWD car 99% of the time. I believe VAG's use a Haldex system which can be troublesome? I like 4wd cars but you must keep well on top of maintenance like changing the fluids in the transfer box and diff's and other stuff like mounting bushes/bearings all need looking after.
Having said this it would be a nice thing to have if our winter's continue the way they have been :|
OdinEidolon
Post by OdinEidolon »
OT Those numbers are hugely overstimated!
OdinEidolon
Welly wrote:They're not actually 4wd in the way we'd like to think, they 'become' 4wd only if the front wheels loose grip so other than driving on wet mud or snow it's pretty much a FWD car 99% of the time. I believe VAG's use a Haldex system which can be troublesome? I like 4wd cars but you must keep well on top of maintenance like changing the fluids in the transfer box and diff's and other stuff like mounting bushes/bearings all need looking after.
The panda 4x4 is also like that and it's amazing off road.
By the way most people buy 4x4 to go on the snow then they buy cheap chinese winter tyres... my 406 with high quality winter tyres will be better on the snow than any 4x4 with cheap tyres.
So, if you plan to go for a 4x4 then calculate both the additional maintenance cost and the cost for 4 decent winter tyres, with chains if necessary. If you just don't want to spend loads on tyres then get a 406 and spend the difference in decent tyres:
- goodyear ultragrip 8
- dunlop 4d
- conti t830p
are the best in the 205/55/16 dimension for around 110 euros (ca. 95 pounds) each here (adac and tcs tests). Then there are the pilot alpin but they cost 50 pounds more each.
406loon wrote:Leon Cupra-R 225
My brother drives one of these - the engine is a total monster (and his is modified), but basically it's a Golf, but with a Seat body shell on it. The interior is made of lightweight rattly plastic.
Bailes1992
Actually both Passat and A4 which I've posted links to are constant all wheel drive :)
Bailes1992 wrote:Actually both Passat and A4 which I've posted links to are constant all wheel drive :)
Which is actually worse - not only has it got all that extra weight, it's also got to drive all those components (at the wheel, as opposed to at the flywheel?). Most real 4x4s can turn one end off.
Btw I saw a Škoda Superb on the road today, I've seen a few about but they're generally hard to spot as they just look like an Octavia that's been eating too many pies, this one must be a new model because the rear end was completely different. The question is why did it look exactly the same size as the Jetta that was along side it?
Actually, today was quite nice being driven about because I wasn't in agony so I could look round and enjoy the scenery. I saw 2 accidents (first being a Freelander II sandwich), a Clio V6 (I bet they're fun but this one was lime green and so plasticky it looked like a designer vacuum cleaner). mind you, it won't look like that for long if he keeps cutting up lorries with it :roll: , a C5 X7 saloon with the back bumper all scuffed and broken and tyres that looked like slicks... Ooh, I see they're selling Police sunglasses here, there were massive hoardings everywhere. It always makes me laugh 'cos it doesn't mean "police" here, it either means shelves (plural of polica) or it's a way of doing baked potatoes ("little halves")
