Probelm staring after clutch replacement
Hello my name is john and im from iceland, I have a 1998 406 1,8l. I was changing the clutch and now the car wont start it turns the engien but it dosent get spark. what can be the problem?
Re: Probelm staring after clutch replacement
check the sensor, on the fly wheel
cranksensor -is it plugged in ?
I'd go with the crank sensor too.
The cranksensor is in his place and plug´d
Have you checked the cranksensor?
took it out,
as it got damaged?
id say it couid only be the cranksensor stopping it sparking. if youve only been working on the Gearbox theres nothing else
ican think of,
took it out,
as it got damaged?
ican think of,
crankshaft sensor, idle control valve/solenoid, temperature sensors, coil pack (if separate unit on your car), throttle pot
