vibration from clutch pedel
kent406
Post by kent406 »
Hope you can help me lol
when i press the clutch pedal in i get a vibration feel from it an it seams to get more with the revs is this normal
pug 406, 2000, to 2l petrol manual
Re: vibration from clutch pedel
It doesn't sound like it :? Is your clutch hydraulic or cable?
hi mate,
sorry idont think thats normal, :(
Worse case scenario Release bearing fault,
just a guess tho withought seeing it /hearing it = guessing game,
kent406
Post by kent406 »
I think its hydrolic as pedal drops down when changing round town. Theres no noise or prob changing gears its working as normal. Ive never noiced it. I didnt know if its a earth thing or engine mounts with it it speeding up as revs go up
Off the top of my head it could be:
Engine mounts
Failed release bearing
Failing hydraulics (or at least in need of new fluid)
New shoes
kent406
Post by kent406 »
well had a quick look in engine bay an think i will start on engine mounts and changing the hydrolic fuild in the line as not sure when last changed and go from there.
ill keep you posted on out come. cheers
craigtd
Post by craigtd »
hi, sorry but what car is it and what engine ?
kent406
Post by kent406 »
its a 2000 reg gtx 2l petrol. ive done a clutch oil change and noticed the gearbox has well id say min amount of oil. ive put 1 litre in already and its no way near filled. so off to pug dealer for more gear oil.
kent406
Post by kent406 »
just an up date which isnt getting better. ive done the clutch fluid but now release barring is noisy but worst is i think something going bad in the gearbox as alsorts of noises arte now cominf from it. when i check it theres was hardly any oil in it. ive but a litre in but it noway filled up. im guess on one more bottle an if not better i think im looking for a gearbox off the site or somewhere.
any idea what one goes for one here or in general pls.
kent406 wrote:just an up date which isnt getting better. ive done the clutch fluid but now release barring is noisy but worst is i think something going bad in the gearbox as alsorts of noises arte now cominf from it. when i check it theres was hardly any oil in it. ive but a litre in but it noway filled up. im guess on one more bottle an if not better i think im looking for a gearbox off the site or somewhere.
Hardly any oil in gearbox?
iwouid fill the gearbox with oil mate,
ihad a rattle on my citreon mainly from Tickover (standing) sounded like thrust bearing,
ive drained off the box and Refilled, its quiet now,
not saying filling the box will cure it but worth a try,
Main stealers for gear oil? whats wrong with places like wilkinsons or Motorfactors for what you pay for 1 litre of oil from stealers you can practicly fill the box for the same money sourced elsewhere :roll:
kent406
Post by kent406 »
well true mate. i think it needs flushing out then refill with new oil. how much does it take to fill
kent406 wrote:well true mate. i think it needs flushing out then refill with new oil. how much does it take to fill
hi,
Edit: just checked in Haynes, its states, 1.9 litres
