gearbox prob
kent406
gearbox prob
Post by kent406 »
i noticed my gearbox is out of oil, i've put 1 litre in so far but not full yet. im comserned there maybe metal bits in the oil as to the noise coming from it most times. so flushing out is a cheep option
how much oil does the gearbox take from empty.
how much does a second hand gearbox cost off here boys an girls
pug 406, 2000, to 2l petrol manual
D9406
2.2 16v
Re: gearbox prob
Post by D9406 »
I think mosy 406 gearboxes take 1.9L of oil from empty but without knowing which type you have it could be more or less.
Silly question but how do you know its empty? To get the level correct all you need do is fill it with the correct grade of oil either through the reverse light switch hole or the filler/level hole until it overflows from the level hole.
martint
2.2 16v
Re: gearbox prob
Post by martint »
Mate don't let it overflow. Do it right. Find out from pug how much it takes
Re: gearbox prob
Just checked in Haynes and other tech manual, it states 1.9 ltrs
