jonsowman wrote:I assume the unmarked thing on the left in the final image is the vac actuator, I can't find a part number for this anywhere.
Correct.
Any ideas what part 1 is in this picture (Reg Vacuum Pump)? It doesn't look like the braking system vacuum pump on the side of the cylinder head.
Am I right in thinking part 5 (electro valve) in the 3rd image is the solenoid for the cruise system?
Correct. When the CC is activated, the pump runs at a constant rate. The solenoid varies the amount of vacuum in the system to control how much the actuator pulls on the throttle.
If anyone has any pictures like image 1 but of a real car, that'd be helpful since I can see where things are meant to go.
Any engine bay shots of a cruise D8 would be good as well, so I can see how the vac actuator is wired up.
You won't find pictures because it's an utter arse to get to and virtually impossible to see with the gearbox in place. It's mounted on the n/s of the engine bay right at the bottom behind the gearbox and beneath the brake fluid reservoir. You can see it from underneath the car, just above the n/s end of the steering rack, but iirc access to the nuts+bolts from underneath is nigh-on impossible on an assembled car.
It's located within a plastic bag which is sealed with a zip and a zip tie. You can see the bottom of the bag on my V6 at the top of this picture taken from just behind the n/s wheelarch, taken with the subframe off the car, driveshafts removed, steering rack swung away, and the engine+gearbox half out. I think the yellowish bit shown to the left of the bag is the front subframe bolting point and to the top-right of the picture is the rear subframe bolting point
I have at some point on one of my V6s (I think the coupé) replaced the solenoid valve. IIRC I wanted to take pictures, but couldn't since the whole job was pretty much done by feel. I worked from above and I had to rip the plastic bag open because the zip at the bottom had jammed. I believe it's 2 nuts and a bolt holding the frame (2 in servicebox) to the body, with an electrical connector on the pump, and another on the solenoid, then it can be lifted out.
The actuator attached to the throttle body is not electrical - its only connection is a hose to the solenoid valve
