As it says in the heading my coolant light comes on quite regularly for a few seconds then goes out, the level is fine when I check it, temp gauge never goes high and fans kick in as normal at 90.
Seems to happen mainly under acceleration in 3rd and 4th gear.
The only thing I can see is what looks like a bit of lime scale round the seal in the coolant reservoir so probably needs a flush but not enough to do any damage.
Any thoughts? presumably sensor related?
Coolant light but level fine
2003 2.2 HDI SE
2003 2.2 HDI SE
Re: Coolant light but level fine
faulty coolant level sensor?
