universal induction filter cone type
tonko007
Post by tonko007 »
Hi all I have a peugeot 406 2.2 hdi can I fit a universal induction kit or will it stuff the engine also does the 2.2 hdi 2002 have a dump valve many thanks paul
Re: universal induction filter cone type
tonko007 wrote:Hi all I have a peugeot 406 2.2 hdi can I fit a universal induction kit or will it stuff the engine also does the 2.2 hdi 2002 have a dump valve many thanks paul
Hi mate.
You shouid be able to fit a u/v induction kit on the 2.2 .
Never heard of any hdi having a dump valve standard perhaps you couid fit one tho.
tonko007
Post by tonko007 »
Only really want to fit one as we get a lot of floods where I live and looks better than the horrible air box and the reason I ask about the dump valve was because I get a little toss when changing gear thanks paul
Hi mate.
If your geting a slight tshh noise you may have a slight boost leak
Leaky pipe somewhere perhaps..
Idont think they fitted em with dump valves
But I might be wrong,
Doggy might know the correct answer, as he's well clued up on the 2.2.
Regards lozz.
davew
Post by davew »
they don't have dump valves they don't work on diesels.
A chap at work has an induction kit on his 306, I will have it when hes finished with it ( he will crash soon ) and I will put it in my air box but cut the top off the box. This way the cold air is still passed up the feed from the wheel arch ( no hot air going in ) but if flooded it can breath through the cut-out in the air box.
Sounds good in theory... :idea:
GingerMagic wrote:A chap at work has an induction kit on his 306, I will have it when he's finished with it ( he will crash soon )
That's not nice is it.... :D :lol:
You haven't seen his driving! - He could probably crash when stationary.....
GingerMagic wrote:You haven't seen his driving! - He could probably crash when stationary.....
Idont think most 306 owners drive as they shouid,
Icarnt slate them anyway.. mines on the pile in the salvage yard :oops:
Oh yes, damn them ebay wishbones.. :(
If anything, I have learned to avoid buying really cheap stuff from eBay and go for the Motor Factors instead...
Are you feeling better?
GingerMagic wrote:Oh yes, damn them ebay wishbones.. :(
A lot better thanks mate.
Still getting greif with my neck..but I can now drive again, its better than looking at 4 walls in the house.
tonko007
Post by tonko007 »
Thanks for all the input ppl can now get a filter cheers again Paul
