Sonia,Sonia406 wrote:Thanks for all your advice everyone!
Usually under breaking the front brakes are binding and cause judder under the pedal etc.
This morning? NONE of that, braked a couple of times and no brake pedal judder and no binding noise or anything - fully functioning brakes!
This car is puzzling me.
Fuel gauge still says half full this morning by the way......
When I bought the car I knew about the exhaust... I had the warning light for the dpf on - all of which - I HAVE sorted.
Too true I got the car extremely cheap so I should expect to spend some money on it.....
When I first got mine the I thought the brakes were terrible (& they were) although it passed it's mot two months before
It would only take the slightest damp road surface to make the ABS kick in on moderate braking
Mine were & they were in a shocking state
The upside of this is after I rebuilt them & replaced the disc's & pad's with pagid one's, Flushed & blead them, then beaded them in they are very good
Night & day to before & after & guess what no more ABS kicking in. I have jumped on them untill I have the hazzard saftey system kick in & NO ABS kicking in unless then road surface is wet.
No need for a Brembro upgrade on my ploder
Hope this Helps DDD.
