Forgive the Q as there may be an obvious answer.
Every time I start the car the heater/blower goes straight to A/C mode. Not needing A/C on, I always have to turn it over to normal fan mode (demisting windows etc)
Is there a setting to control this or does it have to be done through PP ?
Thx
A/C on when starting car
The Rubble Shifter: 2.0 HDi 110 GTX 406 Estate, Tuning Box, K&N Filters.
Thunderbird 4: Mercedes AMG E55, Full Decat & Res Delete.
*New Addition* The Roller Skate: VW Polo GTi
Re: A/C on when starting car
No, they just randomly do this. There's no pattern to it and seemingly no 'cure'.
Practice the Gallic shrug and operating the a/c button without looking.
Doggy wrote:No, they just randomly do this. There's no pattern to it and seemingly no 'cure'.
- kinda what I have been doing - the joys of the 406 - at least we can say they 'aren't boring and every days the same.
Yes bit of a daily routine, I think it may be linked to outside temperature (assuming you'd like the windscreen demisting).
They all do that sir.... I think we concluded (a long time ago ) that it does it if there's a big difference in what's set and what the temperature actually is. Or something. Dunno. Anyway, there is the thought that condensation doesn't just form on the inside of the screen, it'll also form on other cold parts, which would include the electronics inside the BSI, so maybe it's best to let it do it's thang. Unless it bothers you, small drop in mpg, drying out your contact lenses, making your doughnuts go stale...
if you park it under sun or in hot weather, BSI automatically keep the A/C on position with outside air intake mode when you start (ign on) next time.
Used to switch off A/C couple of minutes before I enter the driveway in my D9 executive, and next day morning I always had to manually switch on A/C.
2007, 407SW HDi 2.0l
1980, Volkswagen GolfD 1.6l
1996, 1.8(8v), SL ( The BEST Peugeot I've ever had. It kept me working on it, fixing it almost every day, I miss you)
steve_earwig wrote:They all do that sir....
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
- rwb
That's what I thought.steve_earwig wrote:...if there's a big difference in what's set and what the temperature actually is
But check AC off was always part of the standard start-up sequence.
Indeed, IIRC, goes like this, (D9, full-mux, manual)rwb wrote: check AC off was always part of the standard start-up sequence.
Ignition on
Cancel l/h indicator
De-clutch, select neutral
Engine start...
check AC off...
release handbrake, (optional).
...Clear to taxi
