KWP2000 remap stuff on eBay
RayneR
Re: KWP2000 remap stuff on eBay
Post by RayneR »
mine is semi-mux bosch with serial number ending in 248 and sotfware number 169... i needed a tested map ... but anyway i can't get galletto working well with my car ... i can get the ecu damaged with it ... :(
2000/May 406 Estate 2.0 HDI 110bhp DW10ATED now with 205k km & now with cruise control & now remaped @ 134bhp :lol:
ah right pre multiplex, i went for the fully multiplexed one, it might not be a good idea to use it i don't know what harm it could do but damaging the ecu isn't worth the risk, although hasn't anyone ever remapped a pre multiplex d9 yet?
Ecu files are not interchangeable between semi & fully mux cars.
Nutski had a 2000 vintage 110 remap file, I may have a copy somewhere if you're interested.
RayneR
Post by RayneR »
I already have nutski file :), but unfortunately he's ecu is not the same as mine, despite being pre mux one .. so it's a bit of a risk or not?, and my galletto doesn't work very well on my car ... strange enough because on my friends 406 works ok, i think i have some kind of conflict somewhere on my care, or maybe BSI is just playing up... because i can't get the psa interface to work properly with the engine ecu ...there is some kind of interference ... i also notice this when i enable cruise control, sometimes cruise doesn't work :?
have you got a bosch or siemens ecu?
RayneR
Post by RayneR »
FarmerPug wrote:have you got a bosch or siemens ecu?
bosch, but he's ecu part number is different...
By the way, KWP2000 is better than galletto right ? I mean, if there is battery spikes, kwp2000 can handle it better ? ( i think this is the reason why i cant play with the engine ECU), but well.. at the garage they were able to exchange the old ecu to this new one ... dont know how they managed ... but they coded it to my car and enabled cruise with no problem ... maybe is my tools that aren't " good " ?
Is there much of a difference i used the galetto i got of niel davies last year it did the job great no problems creating multiple backups of the standard 110 file and no problem uploading the remap file, only the coolant fans and airbag light came on during the upload.
RayneR
Post by RayneR »
Then something is going on under the BSI ? So kwp2000 is not so much different than galletto ? So not worth the extra money ?
Nutski file can be uploaded to mine ? ( it would be pointless buying the tool if i don't have any remap file :( ) i bought my galletto in the chance i could buy the file from the ecu tunning site .. but again my galletto doesn't work well on my car.
It's strange, because i was able to backup my ecu file 2 times ... but after that, it works for few seconds then just losts connection. So i don't want that this happens when i'm uploading ...
matt19812009
Post by matt19812009 »
hi guys my 110 hdi saloon is standard but if i use your link what do i need to buy to connect it to the ecu and besides the power upgrade are there any other benefits...cheers
:supafrisk:
jokubelis
Post by jokubelis »
Hello,
Who has 2001 (early, semi-mux) 2.2 HDI defap deegr 180 MAP.
PM me 8)
benczuk
Post by benczuk »
jokubelis wrote:Hello,
PM me 8)
http://406oc.co.uk/viewtopic.php?f=1&t=21237
