Hey all,
anyone know where ican Buy a Coolant Preasure Bleeder from,?
Not many people use them iknow but its something iwant for toolbox.
Coolant Preasure bleeder?
Re: Coolant Preasure bleeder?
like this,
found a kit that will do the job if not better +more uses.
ihope so anyway..
http://www.ebay.co.uk/itm/ENGINE-COOLAN ... 3385464200
ihope so anyway..
That's quite reasonable compared to stuff I saw when I Googled, the postage isn't insanely expensive like most of the stuff I see from the US either (only extortionate
it dont seem abad price,
seen some at just over 250 notes,
thanks
thanks
Lozz,
Why waste your cash, I just use a 1 litre coolant bottle with the end/bottom cut off & a o-ring on the threads so it seals when I push it into the top of the rad/header tank.
Fill it up to the top with coolant mix & open the bleed screws simples
, then lock off the bleed screws & drain the bottle using a length of tube(I use screen wash tube)
Hey presto a pressure blead system, has allways worked for me & I've been using this method for over 15 years
2006 BMW e61 535d m-sport
run's for cover
cheers mate..that method works on some cars,
but it dosent on the ones im playing with they is Mares to bleed,
ididnt buy that one in the link, ive started to make my own, its getting there slowly,
Cheers farmer p
I've made one now.. Out of old rad cap
