http://www.youtube.com/watch?v=pclgBMeGYw8
itake it youve not been behind a leyland atlantian then,
what iwas getting at is this modern stuff is better, Roll with the changes,
Do you have rolling road or dyno figures to back up these assertions? Or are they based on what you "feel" and what you "expect" to happen from using an expensive additive?Bailes1992 wrote: Really? From empty I can get 75litres in my car. 2% of 75litres is 1.5litres.
That means that if I use a diesel that contains 7% bio I get an extra 1.5litres of biodiesel in my tank.
Now consider Millers Ecomax. It's an additive that comes highly recommended and gives a noticeable increase in performance, responsiveness and economy. And it can do all that by just adding a mere 75ml to my 75litre tank, or for an extra 'boost' you can use it at double strength which is still only 150ml. Suddenly the 1.5litres of extra biodiesel in a full tank of diesel seems like a massive amount.
There is nothing wrong with my car. It just really dislikes biodiesel, it's a trait of the 1.8TDCi.
The funny thing is that we've had B7 since 2011, which is significantly beyond your claimed 12-18 month time frame.There has been lots of issues with diesel fuel filters blocking up with a waxy substance in the UK over the last 12-18 months. Roughly around the same time the EU started introducing us to 7% diesel!
And although diesels may few well come from the same refinery it's just the base product. Biodiesel and other additive packages vary from garage to garage and are adding during the filling up process! Therefore diesel DOES very in quality from place to place.
You're wasting your money putting higher-octane fuel in your car compared to what the manual states is required. It does nothing, octane is not a quality rating, it is simply a measure of how easy the fuel is to ignite. Higher octane fuel is actually harder to ignite! This helps with high-compression high-performance (usually turbocharged) engines, to prevent knocking. It does nothing in an ordinary normally-aspirated engine, apart from waste your money.STALLED wrote:Here in AU - our 91ron fuel is 10% ethanol. The Mazda will run on it, but I won't use it for various reasons. Always gets 95 and above!
The 406 XU10 requires 95ron as a minimum (it states it on the filler cap) - it always gets 98ron, as it feels down on power/uses more on anything less. I sometimes might mix half a tank of 95-98 to get something in between, still seems to run alright!
As for diesel, I've never tried Ultimate which you can get here - does it really make that much of a difference? To me, diesel is diesel. Horrid to fill - goes all frothy, you end up in a nasty oil slick by the pumps.....
The only way your Volvo is getting better MPG and more performance from higher-octane fuel is if it's turbocharged, and even then it requires the ECU to be designed to take advantage of the increased ignition resistance. What does the manual state? Unless it states "95 RON minimum, 98 RON recommended for higher performance" or words to that effect, no benefit is gained from using higher-octane fuel.Welly wrote:Bailes why would anyone think you are mad for buying better fuel? I've only ever put Super Unleaded in the Volvo for the last 5 years. I think it's only had '95' Unleaded in twice as an emergency, you get better MPG with higher octane fuel so it just about pays for itself and a petrol engine will benefit from cooler running around the valves and piston crowns, not to mention the ignition can be allowed to advance because no 'knock' will be detected so you get more BHP.
There is no difference between the brands, it simply wouldn't make any financial sense to create and maintain separate lines for each brand, and make sure every station is filled up from the correct truck. It's much easier and simpler to just fill up every station from the same truck.So it appears that Texaco BP Esso and Jet are all owned by the same company (formally Kuwait Petroleum GB) but are the fuels any different between the brands I wonder?????
In that case, 98 can definitely be beneficial, because the engine has been tuned for it. But it also has a knock sensor and the ability to retard timing, so it will run fine on 95 with a slight loss in power.Welly wrote:Hi Kozmo, the Volvo is a 2.5 Turbo and the manual does 'recommend' 98 RON but you can use 95 minimum - I think it says to use 98 to get 'the best performance' or something.
No, I'm a skeptic and a realist.Bailes1992 wrote:Kozmo, I feel that you a bit of a pessimist.
Well then, if there is a difference (more area under the curve), please show the dyno graphs that show this difference. If you can't show it on a dyno graph, it doesn't exist.he cars peak figure never really changes regardless of fuel, but the way in which it delivers it's torque does!
.I can in fact feel the difference using additives and when not. Millers is highly recommended EVERYWHERE with THOUSANDS of happy people. Are you telling me that every single one of them is wrong?
So your car simple gained so much power and responsiveness that it almost got out of hand? Bullcrap.A few times I've added a single dose of millers I've gone to pull out of places or accelerate and the car has shot off much quicker than I've expected. The millers makes my engine feel more eager and 'tighter'.
If the RAC is anything like FDM here in Denmark, it's full of stodgy old geezers who are afraid of anything new, anything designed to improve the environment and anything they don't understand.And to say Biodiesel doesn't cause an issue when it blatantly does in my car is complete nonsense. I've had other work mates drive my car (also car enthusiasts, I'm fussy about who drives my car) and tell me how coarse and lazy it is on 7%.
There is hundreds of people online complaining about poor fuel economy and performance on B7.
Have a read of this!
http://www.rac.co.uk/press-centre/press ... -unexpect/
I can't imagine one of the UK's biggest motoring organizations printing something like that light heartedly.
"Widely regarded" does not make something true. Car enthusiasts on the whole are blithering idiots, without the slightest understanding of chemistry or the nature of the combustion cycle. What probably happened is that you filled up at a station that hardly sees any customers. Fuel can go skunky with age, it's perfectly normal. And perhaps your existing prejudices against "supermarket fuel" kicked in as well.I think you are mistaken when it comes to diesel the same everywhere. It's widely regarded that quality varies from station to station.
My old HDi90 wouldn't return more than 45mpg on Tesco diesel. Started filling up at Shell and was getting 55-60mpg EVERY SINGLE WEEK!
But of course, all diesel is the same.
No, only if your engine has a knock sensor AND the proper mapping for 98 will the higher octane fuel have any effect. As I mentioned earlier, if 98 octane isn't specifically mentioned in the manual, you will gain nothing from using it.Bailes1992 wrote:If your petrol has a knock sensor then it should be able to fully adapt itself for increases in Octane.
I used to run my Focus on Tesco Momentum Unleaded as it used to pink like a b*astard on 95ron!But that didn't have a knock sensor.
And cleaning agents which are frequently used to clear catalytic converters or engine internals don't do anything either, despite countless reports of cars failing emissions tests, then passing easily after a short run after a fuel additive?KozmoNaut wrote:Just as with STP, Redex and whatever else they're called, Millers Ecomax does nothing. The added amount is too minute to make any difference and it's just overpriced naphtha, anyway.
If adding a stupid great supercharger did anything positive at all, don't you think it'd be added to every car under the sun? Imagine the increased market value of being able to claim "our 1.1 eurobox produces 300hp" compared to the competitors, and being able to back that up with hard evidence? But they don't thus proving that superchargers are worthless and a waste of money.If it did anything positive at all, don't you think it would have been incorporated into the standard additive formulation years ago? Imagine the increased market value of being able to claim "our diesel increases performance, responsiveness and economy" compared to the competitors, and being able to back that up with hard evidence? But they can't, so they don't, thus proving that aftermarket additives are worthless and a waste of money.
Funny that, I did extensive testing (several months at 120 miles per day driven at exactly the same speed) with various fuels when I had an XU10 and found a massive difference in economy between supermarket 95RON, branded 95RON and branded 98RON. branded 95 delivered the best mileage for the money followed very closely by branded 98, with supermarket fuels having a drastic ill effect - one notoriously cheap fuel (asda) even reduced distance per litre by about 30%. Now (in the UK) the relative difference in price between branded unleaded and super has shrunk, it's now a false economy to put anything but premium fuel in.You're wasting your money putting higher-octane fuel in your car compared to what the manual states is required. It does nothing, octane is not a quality rating, it is simply a measure of how easy the fuel is to ignite. Higher octane fuel is actually harder to ignite! This helps with high-compression high-performance (usually turbocharged) engines, to prevent knocking. It does nothing in an ordinary normally-aspirated engine, apart from waste your money.pSTALLED wrote:Here in AU - our 91ron fuel is 10% ethanol. The Mazda will run on it, but I won't use it for various reasons. Always gets 95 and above!
My more recent engines (NA V6, I6 and V8s with relaxed maps) have all benefited from premium fuel. The economy difference under controlled conditions is massive. 100RON fuel tested in these cars delivers a further economy benefit, and since economy is a measure of power output against fuel input, it is a given that premium fuels have more usable power per volume unit than cheap fuels. Whether an engine can deliver increased maximum power output on a different fuel is a debate which can only be answered on a dyno... like Fifth Gear did: http://www.youtube.com/watch?v=gQghB4asSnIThe only way your Volvo is getting better MPG and more performance from higher-octane fuel is if it's turbocharged, and even then it requires the ECU to be designed to take advantage of the increased ignition resistance. What does the manual state? Unless it states "95 RON minimum, 98 RON recommended for higher performance" or words to that effect, no benefit is gained from using higher-octane fuel.
and every branded item in a supermarket is exactly the same as it's own-brand value range equivalent as well...There is no difference between the brands, it simply wouldn't make any financial sense to create and maintain separate lines for each brand, and make sure every station is filled up from the correct truck. It's much easier and simpler to just fill up every station from the same truck.
These cleaning agents and additives are already in the standard mandated additive package that all fuel must adhere to according the EU-wide regulations. The reason these aftermarket additives seem to work is because part of the "cleaning procedure" is getting the engine warm and running it through the rev range. A good old-fashioned Italian tuneup will do the exact same thing.mjb wrote: And cleaning agents which are frequently used to clear catalytic converters or engine internals don't do anything either, despite countless reports of cars failing emissions tests, then passing easily after a short run after a fuel additive?
You're being silly now. Adding a big great supercharger has some obvious major drawbacks. For one, it reduces fuel economy severely. It also increases the cost and complexity of the drivetrain, and it requires strengthening other parts of the engine to withstand the boost pressure.If adding a stupid great supercharger did anything positive at all, don't you think it'd be added to every car under the sun? Imagine the increased market value of being able to claim "our 1.1 eurobox produces 300hp" compared to the competitors, and being able to back that up with hard evidence? But they don't thus proving that superchargers are worthless and a waste of money.![]()
Extensive testing meaning "I put some fuel in my car and drove it, in wildly varying weather conditions, on different routes, in changing traffic, with changing loads, different number of passengers, in different moods etc. etc."?Funny that, I did extensive testing (several months at 120 miles per day driven at exactly the same speed) with various fuels when I had an XU10 and found a massive difference in economy between supermarket 95RON, branded 95RON and branded 98RON. branded 95 delivered the best mileage for the money followed very closely by branded 98, with supermarket fuels having a drastic ill effect - one notoriously cheap fuel (asda) even reduced distance per litre by about 30%. Now (in the UK) the relative difference in price between branded unleaded and super has shrunk, it's now a false economy to put anything but premium fuel in.
The economy difference is not "massive", it is extremely minute, and only applicable to engines that are tuned or can be tuned to make use of the higher octane rating.My more recent engines (NA V6, I6 and V8s with relaxed maps) have all benefited from premium fuel. The economy difference under controlled conditions is massive. 100RON fuel tested in these cars delivers a further economy benefit, and since economy is a measure of power output against fuel input, it is a given that premium fuels have more usable power per volume unit than cheap fuels. Whether an engine can deliver increased maximum power output on a different fuel is a debate which can only be answered on a dyno... like Fifth Gear did: http://www.youtube.com/watch?v=gQghB4asSnI
Here's another test conducted with a pair of NA cars: http://www.pistonheads.com/gassing/topic.asp?t=302977
Of course there are detergents and additives in premium fuel. Do you know why? Because they're in the ordinary fuel as well! They're mandated and have to be added to adhere to the standards. The very same standards that the engine in your car was designed for.And then there's the detergent additives they have in premium fuel. Have you any proof to say they don't do anything?
In a lot of cases, yes. Own-brand products are produced at the very same factories as the name-brand products, usually to the same standards.and every branded item in a supermarket is exactly the same as it's own-brand value range equivalent as well...
