Rusted water pipe
Re: Rusted water pipe
If your anywhere near Preston Lancashire you can bring the pipe to me and I'll repair it for you.
- 1.8 8v
That would be cool.lozz wrote:There is an old car shop near me..who seems to keep hold of old/ new stock parts for older motors
I will give them an ask if they've got one if you want..
Or I can forward there number too u ..
Slapped a load of the Chemical Metal stuff from Halfrauds and it seems to be holding. Alas I have discovered how much of an arse it is to bleed the system.
Wiltshirebinnzy wrote:If your anywhere near Preston Lancashire you can bring the pipe to me and I'll repair it for you.
- 1.8 8v
What about this thing?
http://turbo-hose.com/1343.p2-citroen-l ... 343&page=2
Looks like the same thing but without the centre pipe.
Also, can the rubber hoses be taken off the centre pipe? I'm thinking of getting the AC version, but the hose to the rad is different.
The one in the link you posted look's like it won't work, one because it isn't flattened in the middle to clear your
alternator ect, two because the dimensions would probably be way off
2006 BMW e61 535d m-sport
run's for cover
