Now, I've not had much to do with hanging doors, I presume the frame is put in place and screwed or nailed in. Er no, not here.
There were 12 wires holding the frame in. On the LHS it looks like the wall was rendered and then holes smashed into it, then nails driven in, the wires wrapped around the nails and the wall repaired (badly).
On the RHS it looks like the frame was in place before the wall was even built as the wire disappears off into the masonry:
The wires themselves are wrapped around 2 2" nail whacked half-way into the frame and then mangled over:
The frame also appears to have been in place before the lintel over it was poured (in place) as I had to angle grind the inside lip off of it:
So what I've had to do is cut as many of the wires as I could find and then knock the frame into the pantry (so I don't destroy the good plaster on the outside) and cut the wires as I've spotted them.
It's out:
It's now back in around the other way, so I just need to find a way of holding it there (I'll also have to cut about an inch off the bottom of the door as the floor's lower in the pantry). I was thinking
but, as usual, that'll depend if they actually sell them here. We had Miloš on the phone earlier (he wanted to come tomorrow to pull the forms off but I'm at the garage servicing the yoyo) and I got t'wife to ask him what he'd do. Urethane foam apparently
