Definitely worth checking all the high power connections, earth and +ve.
If you don't find a solution, I would probably do the same and hold off buying a battery until next year if you think the coldest part of your winter is over.
Lead acid battery performance is highly dependant on temperature as the chemical reaction required to release the energy does not work as well at low temperatures. - battery capacity reduces by about 1% for every degree below +20C.
How do 406's deal with the cold?
Re: How do 406's deal with the cold?
Doggy wrote:Definitely worth checking all the high power connections, earth and +ve.
Does anybody have a wiring schematic for the earth points?
Peugeot 406 Break - 2.0L - 99kW - EW10J4/RFR - BVM5 - VF38ERFRE80937145
Errr, only for a full-mux, and they're not amazingly useful either.
You'd probably be better off just following the cables...
