Pp2000 AC unit
Pp2000 AC unit
Hi guys.. I never know that. Air condition has its own ecu.. When I scan I saw these codes.. Please what these two faults means? And please where can I locate each of the sensors( AC air temperature sensor and AC coolant temperature sensor)?
Re: Pp2000 AC unit
I'm pretty sure it's controlled by the BSI. Coolant temp sensor is the one with the green connector on the thermostat housing (over the clutch). Passenger compartment sensor is in the overhead console, it's a small clipped in gadget with a tiny fan inside.
Did these both "fail" at the same time?
Re: Pp2000 AC unit
yes that is what pp2000 is showing after scanning
i dont really get what you mean
""Coolant temp sensor is the one with the green connector on the thermostat housing (over the clutch)"" you mean the one inside the evaporator whith brown color? .
"""Passenger compartment sensor is in the overhead console, it's a small clipped in gadget with a tiny fan inside.""" is it together with the evaporator fan, because that is the only fan around.
please elaborate more if you have pictures it will help also
my car is petrol ew10 executive D9 manual transmission.
Re: Pp2000 AC unit
Coolant temperature sensor will be engine coolant, I think it'd say refrigerant if it meant the one in the evaporator
![Image](https://www.406oc.co.uk/download/file.php?mode=view&id=3494)
There's a little fan inside the cabin temperature sensor to draw cabin air over a thermistor so the climate control knows what it's about. The fan is about 15mm in diameter.
![Image](https://www.406oc.co.uk/download/file.php?mode=view&id=3495)
I'm probably not making myself clear as I've got a raging headache, if I'm still not making sense I should be more useful later. Bloody weather![Sad :(](./images/smilies/icon_sad.gif)
Re: Pp2000 AC unit
sorry mate.. for the first diagram..ok that's the coolant temperature sensor which is the same for AC coolant temperature sensor?steve_earwig wrote: ↑Wed Nov 21, 2018 10:02 am Coolant temperature sensor will be engine coolant, I think it'd say refrigerant if it meant the one in the evaporator
I'm probably not making myself clear as I've got a raging headache, if I'm still not making sense I should be more useful later. Bloody weather![]()
while i dont understand the second diagram( i did not see any sensor in it)
Re: Pp2000 AC unit
To get to the passenger compartment air sensor, you need to gently pull down on the part with the grill, then this will expose 2 screws which hold the fan in place..
Re: Pp2000 AC unit
Earlier cars had 3 sensors but I think your car should only have the 1 (what year is it anyway?), so I'm kind of doubting that it's faulty. Cabin sensor as per GM, I'm taking these off of wiring diagrams so all it's showing is the location of the connectors, however a parts diagram wouldn't show anything useful at all.
Re: Pp2000 AC unit
steve_earwig wrote: ↑Wed Nov 21, 2018 11:07 amEarlier cars had 3 sensors but I think your car should only have the 1 (what year is it anyway?), so I'm kind of doubting that it's faulty. Cabin sensor as per GM, I'm taking these off of wiring diagrams so all it's showing is the location of the connectors, however a parts diagram wouldn't show anything useful at all.
model 2001, petrol ew10 executive D9 manual transmission.
Re: Pp2000 AC unit
the front bumper grill, where the relays are situated?GingerMagic wrote: ↑Wed Nov 21, 2018 10:51 am To get to the passenger compartment air sensor, you need to gently pull down on the part with the grill, then this will expose 2 screws which hold the fan in place..
Re: Pp2000 AC unit
No.
Between the sunvisors is the interior light unit. Part of this has a grill on the left - pull this half downwards.
Re: Pp2000 AC unit
![Image](http://i419.photobucket.com/albums/pp280/dogslife_photos/Camera28JUNE2008.jpg?t=1246225438)
![Image](http://i419.photobucket.com/albums/pp280/dogslife_photos/Camera28JUNE2001.jpg?t=1246225592)
Sensor is a little bead thermistor that lives just above the tiny fan.
Usual 'fix' is to get a straw & blow all the gunk out of the fan.
Re: Pp2000 AC unit
Yes.. I saw it this exactly mine with same interior n sunroof(but mail rail is broken, now the roof don't open).. So the code. Clear after I remove the connector n put it back..cheers mate
Re: Pp2000 AC unit
Re: Pp2000 AC unit
Ah splendid
8031 : Passenger compartment air temperature sensor power supply
So that diagram is in PP? I really should have played about with it more but it was scaring me by turning on my door card lights while I was fiddling about with cruise control and I started to wonder what else it would change...
2001 could be either semi- or full-mux, the coolant temperature sender connector is still green for an EW tho.
![Cool 8)](./images/smilies/icon_cool.gif)
Re: Pp2000 AC unit
yes the pic is in pp2000 flow chartsteve_earwig wrote: ↑Thu Nov 22, 2018 9:21 am Ah splendid![]()
is semi-mux
now remain airbags and cruise control.. will soon post the pic.
