Accidentally Pouring Brake Fluid into Power Steering Fluid
k3nny
Post by k3nny »
This morning i accidentally poured 'some' amount of Brake Fluid into the Power Steering Oil box.
i did it because my power steering is leaking oil, so i have to frequently check the level.
this morning i picked the wrong bottle, because they're both the same color. :?
Is it 'ok'? will i get some trouble with this? :cry:
Cars, Computers, Chicks, 3C for a complete life. add a number 6 between them then you get double pleasure. hahaha!
I wouldn't be worried about that kenny, what does the handbook say about the differences between the grades?
It's not ideal but it should mix with the power steering oil and shouldn't cause too much trouble.
If I did that though it would force me into doing a power steering fluid change. Easy job but something we're all guilty of neglecting I believe.
TooT
Post by TooT »
Welton wrote: Easy job but something we're all guilty of neglecting I believe.
Good point. Ive never changed the power steering fluid on any of my cars :shock:
Anyone know when the recommened time is?
jameslxdt
Post by jameslxdt »
no recommended time really, just when it gets to the stage when its turned black rather than red, i would flush the system throughly if its contaminated, as BF is too thin for ATF and certainly wont mix
I'd change it often - Changing the fluid is alot cheaper than changing the pump due to lack of maintenance!
