Noisy engine
I don't blame you for going somewhere else to have the job done. I'm happy with Pug doing it here though as I trust them more than a local garage. Or should I say mistrust them less?
I bottled out anyway, I'll have to drive it to get it to Peugeot but I decided that's my next journey. I cycled home instead. Christ I'm unfit! Then again, to give an idea of the topography here any directions to my house would probably include the words "head towards the mountains".
- 2.0 Turbo
Luckily my little brother works at gsf so i manage to get an even further discount and also he recommends me skilled mechanics who wouldnt screw me over as he would get grief form them its just a pain as my car is everything as i have to drive 50 miles a day to and from work 6 days a weeks which is a killer
ello peeps, bit late in this, but i have been wondering if my engine should be that loud.... 2.1td (d8)
it sounds like a tractor. or a tank for that matter lol
what could help make this quieter? and what could be making it sound loud?
Also, something that hi my mind earlia, as diesels have injectors instead of sparks, do you have to change the injectors, like you would with sparks or not?
many thanks
many thanks
- jameslxdt
only real cause of noise on the 2.1 is the injectors, you can get them overhauled, though it makes more sense to buy new ones, economy will be on the up too
the 2.1 will sound like a tractor.
You don't have to change the injectors unless the are faulty. there not a service part.
Every HDI engine you hears sounds different, doesn't mean there is anything wrong with them, its just the way they are.
1997 Honda Prelude 2.2 VTi
You need the right tool to remove the injectors on the 2.1, the needle lift sensor has a wire to it so the tool needs a slot cut in it. I took mine to Pug, they took it in but 20 minutes later they called me back to tell me they didn't have the right tool... Tools... However, they did tell me where to go, who were very reasonable and, having decent diagnostic gear, were able to diagnose my fault (uneven running) as the needle lift sensor, not the pump as Pug said.
Anyway, D9 booked in for Tuesday so I'm back to driving the D8 (fortunatly I hadn't got round to selling it yet). I had to get insurance on it for 2 weeks and temporary plates, plus it had to go through their version of the MOT (somewhere between "oh, it's got 4 wheels, here you go" and the UK's "if I can't break your car I'll reluctantly give you an MOT"), the whole lot setting me back about 40 squids.
Well, the '9's with Pug in ZG. I explained the noise, showing the mechanic a picture of the crank pulley I pulled off this very site but they were amazed I wanted it all changed on a 3 year old car with only 87,000km on the clock. I explained that I had no idea of the history of the car and I just wanted to be sure there weren't going to be any sudden bangs. The (rather sexy) receptionist said they'd be back to me in an hour with an offer (?).
So, after 90 minutes, I strolled in there and she was still adding stuff up... She said that they reckon my car has indeed done more than 87k (does anyone on here actually trust what the odometer says any more?) because the cam belt is disintigrating.
So they're going to do the big jobby service on the engine - both belts, pulley and waterpump. There were a few other things on the list, the remote wasn't working (all tested as much as I could) which luckily was the circuit inside the key. There was also something else on the list called "spona", it comes in 2 parts and comes to about 90 quid. Huh? The receptionists were all trying to explain what it was but all I got was it's some sort of tie or joiner or button... All I could think of was that I had asked for one of those (stupid) buttions that holds the (stupid) engine cover on as one was missing. I was getting a bit aggitated at the price so they got the mechanic in again - it's one of the arms on the rear suspension! Erm, thankyou for keeping me alive.
The whole lot should set me back about a grand and should be done tomorrow pm. Fortunatly I have a grand handy, it was to pay for heating oil this winter. Crud.
I'm probably old enough to be her dad!
I've been pondering why it sounded ok on the test drive and the 30km journey home but like a tank when I took it for its' safety test. It's either a) I'm a complete gimp or b) something to do with having to keep it in my garage for 3 months before I could start driving it.
The thing is I have a temporary visa here which is renewed every September. The really stupid thing is my vehicle registration is tied into it, so no matter when I register it I have to renew it again in September and it must have 12 months tax, insurance and "MOT" to be registered. So, if I'd registered it back in June, which all costs me about 500 quid, I'd still have to do it all again in September, another 500 smackeroos
I ran it once a week, and took the opportunity to give it a full sevice, swap the new brakes off the '8 onto it and clear some stupid faults. But I never sat inside it, which is where you have to be to hear the noise.
Before you ask, I was looking since last year.
Hi guys, me Pug's back from Pug. I'll scan the bill in later and see if anyone can make sense of some of the part codes 'cos I got tired of pointing to stuff and saying "whassat??" I can already see he's changed both rear track arms, at £70 a pop
So much for their "MOT".
So What the f**k's all this then?
1. Antifreeze - dammit, I just changed that!
2. (Stupid) engine cover (stupid) button
3. Used materials - coffee, sugar...
4. Some sort of vegetable?
5. "Double belt pulley" - presumably everyone's favourite crank pulley.
6. Washer or seal - ?
7. Gaskets?
8. Water pump
9. Rear bush?
10.Track arm
11.Track arm
12.El Belt
13.something that stretches something else??
14.ditto
15.Grease against going out from the garden??
16.Cleaning spray
Below that is stuff needed to complete the work:
1. Labour
2. Other services? All I did was shake her hand!!!
Hopefully one of you clever chaps has some access to a parts catalogue. While I couldn't get in this site earlier I talked to my brother in GB and he's getting me one so next time I can avoid this sort of thing, plus use numbers instead of words...
So no more paranioa for the forseeable future. Prices are in Croatian Kunas, I'm wondering how they compare. My usual converter. Quite a bit to shell out but hopefully that'll be it for a very long time.
There's just one problem though: It's still making that noise! ARGH!!!!!!! D.C. al capo
7. Gaskets?
8. Water pump
9. Rear bush?
10.Track arm
11.Track arm
12.El Belt
14.ditto
16.Cleaning spray
1. Labour
