bsi fault???
bsi fault???
ive had a look at the 406 hdi 1999 ive just bought & found a few faults
1. the ignition lights stay on with the key removed
2. if you disconnect the battery them reconnect it the mileage briefly reads 923700.00 then goes to 0000 with a spanner next to it & 000000 underneath it
3. it turns over but will not start
4. you can turn the heater on with the key out
5. the rdio will not turn on with or without the key
any ideas
any ideas
- 1.8 8v
Had some of the symptoms you have.
First off stip out the ignition barrel and have a look at the switch. mine disintegrated and stuck at poisiton 2.
The key being lit up is almost certainly the immobiliser although my did this after the switch disintegrated.
If you need to get a new key coded, look at around £26 to have the original code ordered from peugeot and £120 for the key including coding and cutting.
good luck.
DW
good luck.
DW
I've heard of those corroded connections before somewhere.
This bit of info I just found on the immobiiser/BSi looks quiet good Linky BSi PDF
Re: bsi fault???
well the bsi has had to be reset to factory standard£125 inc vat & postage but i will need to get it reprogammed to the car so theres another £20 for the code & £40 to get it programmed.
hopefully i'll have it running this week
Re: bsi fault???
well i put the bsi in today & it still has the same fault so that will have to back to bba but i got a bsi, ecu & key chip from the scrap yard today(foc) & it fired up first try but it will not rev over 3000 so ive gone from one problem to another
Re: bsi fault???
it'll be in limp home mode for some reason.
you need to get the fault codes read.
1997 Honda Prelude 2.2 VTi
