I know, i should have known better, i had plenty of warnings, the red lights, flashing messages on the radio screen etc. Well, after filling up on the road side now it started as normal after a few trys, but after driving for a few minutes everything dies. It just cuts out, no steering, no power, no brakes, the engine just dies. Now the enigne K light is on constantly. First thing i thought was air in the fuel system, (btw i'm no mechanic, i've just picked stuff up over the years watching me Dad work restoring vintage vechicles), so i start looking for a fuel primer or a bulb in the fuel line to bleed air out with. Can't find any. So i tried the old trick i used on an old Astra i had years ago, unscrewing the injectors while turning over the engine. It spluttered letting the air escape. Cool i thought that had solved the problem. Started the car and drove around for a while but the problem was still there, it cuts out after 5 mins.
Then i thought that there may be dirt in the filter. Checked the filter but the fuel is coming out clean from the bleed screw on the bottom. Then it happens......I attempted to take of the fuel filter cap and in the proceess of removing one of the pipes from the top with those akward push fittings i broke it. It just snapeed right off!
So heres the questions:
1. What is causing the car to cut out?
2. How i fix it without taking to a dealer?
If anyone can help it will be much appriciated. Thanks!!!!!!
