406 sri turbo exhaust
sriturbO
Post by sriturbO »
406 sri turbo exhaust pipe diameter anyone know?
mikey s
Re: 406 sri turbo exhaust
Post by mikey s »
2.5 inchs.
1990 205 gti16, xu9j4 power! graphite grey, white speedlines, 306 brakes, ice, half leather.
going to enjoy smashing ctr's
2000 d9 406 executive v6 estate with an auto box, bit of a hot hatch slayer ;) currently munching 'hot' hatches.......
sriturbO
Post by sriturbO »
ok cheers mate thinkin of a 3inch or maybe 3 1/2 inch custom one wot u think
mikey s
Post by mikey s »
in all honesty unless your looking for plus 200bhp stick with 2.5inch. the guys on 205 gti drivers have done some tests on 2.0 turbo exhausts and the general consensus is 2.5 inch seems to work the best. peugeot tend to make some cracking standard exhausts, all length tuned to perfection etc. i wouldnt waste your money on a stainless one, just buy a good standard one.
sriturbO
Post by sriturbO »
cheers mike i will be going for around 200 bhp or maybe more so ill go with 3inch as i cant find a standard one in stainless anyway and i also cant find a decat for it so kinda makes sense to get it all done in 3 inch pipework
Deano
Post by Deano »
sriturbO wrote:cheers mike i will be going for around 200 bhp or maybe more so ill go with 3inch as i cant find a standard one in stainless anyway and i also cant find a decat for it so kinda makes sense to get it all done in 3 inch pipework
Just a note to remember if you are in the UK then you will need to refit a cat for MOT each year
2.0L 8V TURBO EXECUTIVE 150BHP+TOYS ZRX1200R AND MK1 EUNOS ROADSTER
pugsport
Post by pugsport »
I had a powerflow custom exhaust put on mine 6yrs ago only cost £240, much cheaper than OEM plus lifetime garuantee so it is not a waste of money, considering I would normaly have to replace standard exhaust every 2 or 3 yrs!
A 2.5 would be okay for 200bhp.
MODIFIED 1997 406 SRI; FULL ECOSSE TOURING BODY KIT;CUSTOM EXHAUST;
17"FOX ALLOYS;DUMP VALVE;
INDUCTION KIT;LOWERED 40MM.
LEXUS STYLE REAR LIGHTS;
DTM STYLE MIRRORS
pugsport
Post by pugsport »
Hi Deano, is it cold enough for you?
DTM STYLE MIRRORS
Deano
Post by Deano »
TO COLD :(
Tiny Tim
Post by Tiny Tim »
As far as exhaust systems og on petrol turbos, for the best performance you want the system to be as short and large a bore as possible with as little bends. Its all about restrictions. Mind you, if you're going to stick a large bore exhaust on and keep the standard downpipe + turbo elbow, there's no point.
mikey s
Post by mikey s »
im not sure i completely agree with you there. if the bore is too big, gas velocity is reduced to such an extent that reversal occurs which is a bad thing. if you could put up with the noise having no silencers in a turbocharged petrol exhaust is good. the turbo creates all the backpressure that the engine needs.
the turbo elbow on the xu10 engine is part of the exhaust turbine housing so the only way to change this would be to change the turbo.
Tiny Tim
Post by Tiny Tim »
Sorry mate, but the theories wrong... you dont want back pressure on a turbo'd engine.. think about it.
Just the thing for a two stroke tho :P
sriturbO
Post by sriturbO »
ok im going for 3 inch decat into 3inch straight through center into a 3 inch baffled box of the tombstone variety
Tiny Tim
Post by Tiny Tim »
Why not go for a side exit? 8)
